Small utility trailer towed by tractor?
   / Small utility trailer towed by tractor? #1
ratter
Westmoreland CO, PA
Massey Ferguson 1540
This is about as newbie as a question gets, but I figure better safe than sorry...
I'm thinking of getting a small 5x10 utility trailer (the Lowes/TSC style...) for hauling implements and other random things with my SUV. Is there any reason why I can't also pull it behind my tractor when the need arises?
   / Small utility trailer towed by tractor? #2
When I lived in the country, I had a 5' x 10' tilt bed trailer, and my brother's 6' x 16' tandem axle trailer stayed at my place. I used both of them at different times behind my Kubota B7100 and B2710. Just remember, if you load a trailer pretty heavy that tractors will pull more than they can stop. Don't get to going too fast, especially downhill, and you'll be fine.
   / Small utility trailer towed by tractor? #3
Just how much can a tractor pull? Mine's 55 HP, but with it in low gear, I bet it's a lot more than my truck can. ???
   / Small utility trailer towed by tractor? #6
Just a word of caution here. If your going to tow it, put the ball on your hitch (mounted firmly to tractor). If you have it on a drawbar from lift arms for 3ph, without some stabilizing bar, the trailer can sway side to side (be sure to adjust sway/stabilizers for this). It can also rear up if load is not centered properly (weight forward on hitch), and if you have to stop suddenly, it could rear up and push/jacknife/turn over. FYI.
   / Small utility trailer towed by tractor? #7
I have a 6" bandit chipper on a trailer that weighs about 2000lbs
Do you think a Kubota BX24 could move it around 2 acres.
I could get to some spots with the tractor that I couldn't with the crew cab truck.
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
Caterpillar 430D...
New Long Forks (A53002)
New Long Forks...
2012 FORD E-SERIES 11 PASSENGER VAN (A52472)
2012 FORD E-SERIES...
