Small tractor performance
   / Small tractor performance #1
mcnitt
Nevada City, California
Kubota GL3430
How steep a hill should my MF 1220 (3 cyl. 20 hrsp. hydrostatic) be able to climb? The tractor quickly fails to move forward on even a moderate incline. (Couldn't even get up the loading dock ramp at the repair facility) The engine RPM stays up, but the transmission strains and I can feel it trying to move with my foot on the clutch pedal. Also, the tractor fails to move in the high range on anything but the flatest part of my property. I had a dealer replace the fluid and filters, but I don't think it helped much. The tractor also fails prematurely in the low range I think once it warms up.
Anybody have a clue what's going on?
   / Small tractor performance #3
Sounds as if either the clutch is out of it, or the hydro is getting weak.
   / Small tractor performance #4
If it is a hydrostat, you have to let the pedal up as the pull gets harder. The hydro pedal works opposite of an accelerator pedal. We are all so programmed using an accelerator pedal in cars and trucks that we tend to use the hydro pedal like an accelerator. When in essences, it works just the opposite. If you knew all of this please disregard.
No, I didn't know that. I use the pedal just like the gas pedal in my car. I think I have tried the pedal in every possible position, but I will try what you suggest. I'll try it, but I don't understand why it would work.
Thank You for replying.
What do I do to get the hydro back to where it functions properly?
Thank You for your help.
   / Small tractor performance #7
Have you checked the hydraulic oil level? Even if it was just changed at the dealer I would check to make sure it is at the proper level. If that is not the problem I would contact the dealer and get his opinions.....
   / Small tractor performance #8
I don't understand what that means. I push the pedal to go faster or for more power. It sounds like you are saying let off the pedal to do that. Sorry, I am kinda slow.:confused:
   / Small tractor performance #9
Pushing the pedal down on a hydro is like going to higher gear. If you push the pedal just a little, that is where it has the most power. Any more is like a higher gear.
   / Small tractor performance #10
If your HST is properly functioning, it would kill the engine if you pushed the pedal down too far for the load being put on it. Jerry failed to mention that part. What he is saying is correct as for the overall gear ratio of a properly functioning system. I understand you to say your engine does not labor, the tractor just won't move. That indicates HST failure. Bummer.
New/Unused Electric Golf Cart (A57453)
New/Unused...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Ratchet Straps (A59230)
Ratchet Straps...
Leer Camper Shell (A57454)
Leer Camper Shell...
Cameras and Video Camera (A56860)
Cameras and Video...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
