small tractor/loader
/ small tractor/loader #1
morris
Does anyone know if there is such a thing as a small tractor/loader with outside width of less than 42 inches, also a belly mount mower would help.
/ small tractor/loader #2
Morris -
I've used the <A target="_blank" HREF=http://www.bobcat.com/cgi-bin/view.ssl.ind.cgi?model=463>Bobcat 463</A> a few times, and it's one powerful little machine. It can squeeze through a 36" door and do a lot or work. No belly mower, of course, but with the Bob-Tach system, you can probably stick one on the front.
Something to look at anyway.
/ small tractor/loader #3
Morris,
From memory (take with a grain of salt) the B7400 minimum is ~ 38" and the B7500 is~43". This is with the tires all the way in. Also there is a narrow version of the B7500. I don't think Kubota makes a loader that is less than 42" for these tractors.
Al
/ small tractor/loader #6
Here are some of the specs on Yanmar tractors. The four digit models are Grey market and widely available.
Cameron
Model HP YL Trans Year Weight L W H
YM 1100D 4 WD 14 2 gear drive 77-82 948 72" 34" 45"
YM 1110D 4 WD 13 2 power shift 77-82 1020
YM 122 2 WD 12 1 gear drive 84-89 829 YM 1300D 4 WD 16 2 gear drive 75-80 1135 81" 38" 65"
YM 1301 2 WD 16 3 gear drive 81-83 1124 85" 38" 68"
YM 1301D 4 WD 16 3 gear drive 81-83 1190 85" 38" 68"
YM 135 2 WD 13 2 gear drive 77-81 995 YM 135D 4 WD 13 2 gear drive 77-81 1090 YM 140-2 2 WD 14 2 gear drive 84-89 1406 YM 140-4 4 WD 14 2 gear drive 84-89 1505 YM 1401 2 WD 18 3 gear drive 79-81 1080 84" 38" 69"
YM 1401D 4 WD 19 3 gear drive 79-81 1168 84" 38" 69"
YM 146 2 WD 14 2 gear drive 84-89 884
/ small tractor/loader #7
Nicklan.
Nope Its not Ingersoll-Rand, Its just Ingersoll. Two seprete companys.
/ small tractor/loader #9
The Ingersoll would be something to look at. Not sure on the exect size, but they are small, and built like a tank. A new model they just came out with also has 4wd.
/ small tractor/loader #10
John Deere made a version of the 4100, the 4100N that is specified at 36" wide with the Ag tires, but they don't list a loader as being available for this model. Maybe an after-market loader could be fitted?
- Rick
/ small tractor/loader #11
Nope, Looks like the Ingersoll may be a little big for you also. Heres the specs.
<A target="_blank" HREF=http://www.ingersoll-inc.com/6000seriesspecs.html>http://www.ingersoll-inc.com/6000seriesspecs.html</A>
/ small tractor/loader #12
Heres the specs. for the 4wd tractor just in case.
<A target="_blank" HREF=http://www.ingersoll-inc.com/7000seriesspecs.html>http://www.ingersoll-inc.com/7000seriesspecs.html</A>
/ small tractor/loader #13
Have you thought of an old Massy/Fergesun 1010 ? I don't know if you can get a loader for one, but the size fits the bill. My local Long dealer has 2 of them sitting out on his lot, I'll check them out next time I'm down there.
Ed King
2020 Ford Transit 350HD Cargo Van (A61573)
2020 Ford Transit...
2001 Ford F-650 18ft Rollback Truck (A61573)
2001 Ford F-650...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
UNUSED WOLVERINE RCR-12-84W-84" HYD ROCK RAKE (A64281)
UNUSED WOLVERINE...
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
