Small tractor hay baling???
/ Small tractor hay baling??? #41
I thought of that too but the two balers weigh almost the same. Its a shame no manufacturer ever put a counter balance in the machine to soften the stroke. The rocking wears hitchs out fast.
/ Small tractor hay baling??? #42
Well i really don't know what all the fuss is about!! :D I use a 1965 MF135 diesel with an old MF#3 baler or NH273, a NH469 9' Haybine and mow and bale 60 acres every year for last 20 years without the slightest problem. I have rolling and hilly terrain, no loaded tires, lots of HP and have never felt that i was being unduly "rocked around" by the balers. JJ.
/ Small tractor hay baling??? #43
Most of my years of "hayin'" were with a 273 New Holland. (I bought a Deere 336 about 5 years ago) The 273 (and likewise the #3 Massey baler) were designed and built with small farms and small tractors in mind. They are good choices if someone wants to bale with a compact IMHO. I'll always believe the guy who "invented" the New Holland baler owned a round barn though. :) All those bananna shaped bales were hard to stack in a square building!
Still have my #56 rake and #451 mower. Old 273 finally just had enough....Must have baled a million bales in it's lifetime.
/ Small tractor hay baling??? #44
I agree, I am using a NH 426 and it has intersting shapes if the bale chamber is not fead evenly.
The best for squarness was an old Massy 35. It was a great bale, square and dependable, but sloooow.
The new hesstons are taking over here.
Don't think of taking somthing like a 400 seires baler without atlease 60 hp.
/ Small tractor hay baling??? #45
Yes i have to agree with that. I mostly cured the 273 of the Banana bale business by installing a bale retarder kit. Still makes a good bale as long as the windrows are not to light. I don't believe how well the old #3 MHF still works after all this time. JJ.
/ Small tractor hay baling??? #46
I learned to live with the 273. Constant adjustments on the bale tensioner kept the bales reasonably straight. Just more adjusting than other brands.....
Dad had a #3. He bought it after I moved out on my own, so I didn't get much time with it.
When I bought the Deere 336, I found out that there was such a thing as a baler that you adjusted and left it alone. I'd go an entire summer with minimal wrenching. Just a visit with the grease gun and fill the twine box. Always wanted to try a NEWER New Holland.
Doesn't matter now. No more baling for me! In an hour or so, I'm headed out at first light to start discing 28 acres of old pasture to get ready to seed. Gonna turn 'em into hay fields, but my son will bale for me now. He's got a new round baler. (Vermeer Rebel 5400) I farmed for 35 years without ever owning a baler newer than 10 years old (when I bought them) The boy's owned his place for a year now, and already has all new hay equipment. He's got big ideas and big PAYMENTS.
/ Small tractor hay baling??? #47
That'll make you count the threads on either side of the tensioner!
/ Small tractor hay baling??? #48
Does anybody out there have any actual experience owning/using the Jinma TC24 small round baler? Is it well built? Is it reliable? I haven't been able to find any user discussions about the TC24.
/ Small tractor hay baling??? #49
Hi, guys i just wanted to tell you all what my expeierences are with compact tractors and hay. I have used my Mf 1540 4wd with 1525 loader and R-4 tires the rears are the oversized tire and they are loaded somewhere between 800-1200 lbs in fluid. I have a MF 12 square baler with bale thrower attachment i used this baler on this tractor on a field with a hillside i didn't have any problem the process was slower than with a big tractor but it handled it fine. It didn't toss the tractor as much as it toss my big tractor but the reason for that is the the mf has a bolt to tighten the drawbar up from being loose. I have also used a NH 845 chain round baler on this tractor in the same field and it run it just as easy the square baler if not easier, again the process was slower than a bigger tractor but done the job. This is just my expierence, but i would not want to do any more than just a few acres like that though, to slow
/ Small tractor hay baling??? #50
Not to beat an aging post to death but I needed an excuse to hit the 500th post. Woo hoo!
I recently purchased a sickle bar mower from a farmer who was using a 33 HP New Holland (gear drive) to run a John Deere 24T hay baler.
He said he never had a problem using his compact to run this particular baler and his land has plenty of hills. He said it worked like a charm.
14in Digging Tooth Bucket Excavator Attachment (A60352)
14in Digging Tooth...
FIFTH WHEEL ATTACHMENT PLATE (A60736)
FIFTH WHEEL...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
1979 HEIL TRANSPORT TRAILER (A60736)
1979 HEIL...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
Misc Mechanical Fuel Dispensers (A59317)
Misc Mechanical...
