Small tire options
/ Small tire options #1
prichard
N. Georgia
B2601 FEL
I have DR chipper with 410/350-6 tires. There are dry rot cracks and one keeps going flat. Replace or tube?
Thank you Steve. How hard are tires to mount on those rims? I had no issue inflating fully flat, off the rim tire, but have not tried mounting one.
/ Small tire options #4
How about using one of the 4.00-6 foam filled ones meant for a hand truck or wheelbarrow? HF has a knobby "13 inch" one for about $22 which might fit, depending on your axle size. Then never worry about flats again...
interesting, I never would have though to starch my tires.
I was looking at the foam filled on Amazon. Tempting since I'd never have to be concerned about low tires.
/ Small tire options #6
I have DR chipper with 410/350-6 tires. There are dry rot cracks and one keeps going flat. Replace or tube? <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=465548"/>
Replace. Bought my replacements from Amazon. Better than original. $16 each.
Sent from my iPhone 2.0 using TractorByNet
Tufline Box Blade (A64047)
Tufline Box Blade...
20’x30’ All-Steel Carport w/ Enclosed Sidewalls (A64047)
20’x30’...
New Holland TC21 (A62177)
New Holland TC21...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
