Small tire options
/ Small tire options #1
prichard
N. Georgia
B2601 FEL
I have DR chipper with 410/350-6 tires. There are dry rot cracks and one keeps going flat. Replace or tube?
Thank you Steve. How hard are tires to mount on those rims? I had no issue inflating fully flat, off the rim tire, but have not tried mounting one.
/ Small tire options #4
How about using one of the 4.00-6 foam filled ones meant for a hand truck or wheelbarrow? HF has a knobby "13 inch" one for about $22 which might fit, depending on your axle size. Then never worry about flats again...
interesting, I never would have though to starch my tires.
I was looking at the foam filled on Amazon. Tempting since I'd never have to be concerned about low tires.
/ Small tire options #6
I have DR chipper with 410/350-6 tires. There are dry rot cracks and one keeps going flat. Replace or tube? <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=465548"/>
Replace. Bought my replacements from Amazon. Better than original. $16 each.
Sent from my iPhone 2.0 using TractorByNet
Yanmar YT359 (A53317)
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
John Deere Z997R (A60462)
John Deere Z997R...
