flingwing1969
Platinum Member
- Joined
- Jun 2, 2008
- Messages
- 688
- Tractor
- LS G3038, JD GT275, and Bolins H16
Shop Items You Should Have
• Two complete sets of combination wrenches
• Complete set of regular and deep-well sockets and ratchet wrenches – ½” if you can only afford one
• Large breaker bar
• Good compressor with fair capacity – no pancakes here
• Large high capacity air wrench
• Grinder or two with grinding wheels and cutoff wheels – 4 ½” works but one of those and 8” is better
• Learn to weld and do it often so get a nice welder when you can – 180amp or better
• Plasma cutter, oxy/ace set, chop-saw, cold cut saw or the like (all is better) if you will be fabricating
• A good grease gun (cordless electric is great) and a Locknlube® Grease Coupler will make your life easy
• Work Lights
• ½” Drill and quality bits up to ½” in size (two of each you’ll appreciate)
• Drill press and bits
• Pry bars
• Etc, etc, etc.
Tractor Carry Items
• Spare key
• A good fire extinguisher mounted on the tractor
• Extra hairpin clips
• Extra ouch clips
• Extra TPH Pin or pins
• Spare Shear Pins (as appropriate)
• Spare fuses - at least a couple of each your tractor uses
• A small first aid kit.
• Ear muffs
• Gloves
• Shop Rags or Paper Towels
• Set of combination wrenches for common nuts/bolts on your tractor
• Properly sized adjustable wrench
• Silicon fusing tape – for emergency repairs
• Zip ties
• Flashlight and spare batteries – keep one of the flashlight batteries backwards in the flashlight to prevent discharge over time as you are unlikely to use this much
• Channel-Lock pliers
• Tubeless tire plugs – you may not be able to fill a tire but you might catch it before it’s flat and limp home
• Hammer or better yet, a hatchet with a hammer end on it
• Waterless hand cleaner would be appreciated after a greasy field repair
Tractor Mods You Will Appreciate
• Work lights front and rear, heck put one on each side too – use relays, fuses, and waterproof switches
• Horn – I know, HUH? You’ll be surprised how often you use it when working with friends and family
• Tool/materials boxes where ever you can find a spot for them
• At least one chain box/basket mounted somewhere
• SSQA if you don’t have one and if your FEL capacity will handle the weight and still serve you
• TPH quick connect, unless you keep your backhoe on most of the time like I do
• 2” trailer receiver on the front – they do more than give you the ability to push a trailer
• Bucket/forks chain hooks – either welded on or quality bolt on hooks
• Cup/bottle holder – find a place to put it and you’ll love it on a cold/hot day
• Inclinometer for those tippy times – cheep, look kinda cool, and available from Jeep shops
• Top quality battery – the one that comes with most tractors are not. Mine is 50 amp hours and they want $300+ for a replacement when I can get a 125 amp hour car battery for well under $200.
• Two or three good length ratchet straps - you'll find a world of uses for them
• Large breaker bar
• Work Lights
• Pry bars
• Etc, etc, etc.
Tractor Carry Items
• Spare key
• Extra ouch clips
• Ear muffs
• Gloves
• Zip ties
