Small stuff that I didn't think I needed
   / Small stuff that I didn't think I needed #41
Shop Items You Should Have
• Two complete sets of combination wrenches
• Complete set of regular and deep-well sockets and ratchet wrenches – ½” if you can only afford one
• Large breaker bar
• Good compressor with fair capacity – no pancakes here
• Large high capacity air wrench
• Grinder or two with grinding wheels and cutoff wheels – 4 ½” works but one of those and 8” is better
• Learn to weld and do it often so get a nice welder when you can – 180amp or better
• Plasma cutter, oxy/ace set, chop-saw, cold cut saw or the like (all is better) if you will be fabricating
• A good grease gun (cordless electric is great) and a Locknlube® Grease Coupler will make your life easy
• Work Lights
• ½” Drill and quality bits up to ½” in size (two of each you’ll appreciate)
• Drill press and bits
• Pry bars
• Etc, etc, etc.
Tractor Carry Items
• Spare key
• A good fire extinguisher mounted on the tractor
• Extra hairpin clips
• Extra ouch clips
• Extra TPH Pin or pins
• Spare Shear Pins (as appropriate)
• Spare fuses - at least a couple of each your tractor uses
• A small first aid kit.
• Ear muffs
• Gloves
• Shop Rags or Paper Towels
• Set of combination wrenches for common nuts/bolts on your tractor
• Properly sized adjustable wrench
• Silicon fusing tape – for emergency repairs
• Zip ties
• Flashlight and spare batteries – keep one of the flashlight batteries backwards in the flashlight to prevent discharge over time as you are unlikely to use this much
• Channel-Lock pliers
• Tubeless tire plugs – you may not be able to fill a tire but you might catch it before it’s flat and limp home
• Hammer or better yet, a hatchet with a hammer end on it
• Waterless hand cleaner would be appreciated after a greasy field repair
Tractor Mods You Will Appreciate
• Work lights front and rear, heck put one on each side too – use relays, fuses, and waterproof switches
• Horn – I know, HUH? You’ll be surprised how often you use it when working with friends and family
• Tool/materials boxes where ever you can find a spot for them
• At least one chain box/basket mounted somewhere
• SSQA if you don’t have one and if your FEL capacity will handle the weight and still serve you
• TPH quick connect, unless you keep your backhoe on most of the time like I do
• 2” trailer receiver on the front – they do more than give you the ability to push a trailer
• Bucket/forks chain hooks – either welded on or quality bolt on hooks
• Cup/bottle holder – find a place to put it and you’ll love it on a cold/hot day
• Inclinometer for those tippy times – cheep, look kinda cool, and available from Jeep shops
• Top quality battery – the one that comes with most tractors are not. Mine is 50 amp hours and they want $300+ for a replacement when I can get a 125 amp hour car battery for well under $200.
• Two or three good length ratchet straps - you'll find a world of uses for them
   / Small stuff that I didn't think I needed #42
Well I saw chains mentioned a few times but not much attention paid to ropes and straps.
For chains get a bunch, different thickness, different lengths.
I bought most of my chains at HF, 5/16 x 20 ft but GAD they've gotten expensive. I was paying about $25 back in 2009, now they were $40 w/ coupon and will probably be a lot more with a 25% steel tarrif. And get load binders.
I cut the chain up for different sizes, have some dedicated for strapping the tractor down some for towing things. I've got a few 1/2" chains for when loads get serious.
Also get plenty of different sized rope and twine. I've bought since 2009 1/2" bull rope, 1/2" nylon (x 300 ft), 1/4" nylon (x600'), 1/4" manila (x600 ft) and nylon twine (1,000 feet), all bought by the roll. And some sizes I'm starting to run out of. If I'm going anywhere more than a few yards from the shop I always make sure I've got some 1/4" or better with me.
I also like ratchet straps but some people don't.
   / Small stuff that I didn't think I needed #43
• Large breaker bar
• Work Lights
• Pry bars
• Etc, etc, etc.
Tractor Carry Items
• Spare key
• Extra ouch clips
• Ear muffs
• Gloves
• Zip ties
• Flashlight and spare batteries – keep one of the flashlight batteries backwards to prevent discharge
Nice list... and thanks for producing it. :thumbsup:
   / Small stuff that I didn't think I needed #44
Yes on this good point and I added it to my list for sure - especially ratchet straps, I always carry a couple as they are easy to use for stabilizing a load on forks or in the bucket. Ropes can be handy but if space is at a premium, you can do most of what you need to do with the straps and they don't take up nearly the room - and many don't know how to tie a good trucker's hitch or other hitches/knots.
I also forgot to add spare fuses to the list.
2023 yamaha (A55758)
2023 Kubota L2502DT (A53317)
2023 Kubota...
UNUSED FUTURE HYD MINI THUMB CLIP (A57193)
UNUSED FUTURE HYD...
2012 BAD BOY CLASSIC ELECTRIC GOLF CART (A57192)
2012 BAD BOY...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
Water Trough (A56469)
