Small storage tank?
   / Small storage tank? #1
Slippy
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
Read a lot about cons of storing fuel. Has anyone seen a say 20 to 30 gallon storage tank that has a pump built in? Biggest problem with 5 gallon cans for me is lifting them up on top of the tractor and then not spilling it all over the place. Any ideas? I was going to get a 55 gallon drum and fill it about 1/2 and put hand pump on it, but a drum that size can be difficult to move from the truck to the floor, etc.
   / Small storage tank? #2
I have a 30 gallon poly barrel I plan to use for that purpose soon. I have a hand pump and as soon as I clean out the drum, I'll be putting it together.
Where would one find such a barrel. 30 gal sounds about right.
   / Small storage tank? #4
Todd makes a Diesel Caddy. Click Here
Checked EBay. There is one for $315 in Buy It Now. /forums/images/graemlins/blush.gif
My back is not that sore yet. /forums/images/graemlins/tongue.gif
   / Small storage tank? #5
Slippy,
In Columbus, there is a recycler of drums/barrels. Container Management Company near I-71 and 5th Ave. Cost me $26.00 +tax. I have the phone number if you'd like via PM.
Jerry: Thanks. They are on Corrugated Way and I got their number. Will call them tomorrow. Thanks again.
   / Small storage tank? #7
</font><font color="blue" class="small">( Read a lot about cons of storing fuel. Has anyone seen a say 20 to 30 gallon storage tank that has a pump built in? Biggest problem with 5 gallon cans for me is lifting them up on top of the tractor and then not spilling it all over the place. Any ideas? I was going to get a 55 gallon drum and fill it about 1/2 and put hand pump on it, but a drum that size can be difficult to move from the truck to the floor, etc. )</font>
I'd suggest about 100 gallon tank to be useful. You can use your FEL to hoist it full up to the top os a frame you'll build so that it can refuel all your diesel powered equipment via gravity flow. If you have a diesel truck and tractor, and maybe even a generator; you can supply all from one storage tank. You can get the stabilizer additive from marine stores if you think water and bateria are a problem.
Suitable tanks can sometimes be had from furnace supply stores, get one made to hold fuel oil, Furnace oil #2 and #2 diesel are the same thing, so all the fittings are fine.
Pat
I do have an old fuel oil tank. Will it work? Has been sitting for about 10 years. Best way to clean it out?
   / Small storage tank? #9
</font><font color="blue" class="small">( I have the phone number if you'd like via PM. )</font>
Please PM me the number.
Thanks.
   / Small storage tank? #10
</font><font color="blue" class="small">( I have a 30 gallon poly barrel I plan to use for that purpose soon. I have a hand pump and as soon as I clean out the drum, I'll be putting it together. )</font>
I'm looking for a 12 15 18 or 20 gallon container.
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A54814)
2016 Autocar...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A52377)
2014 Peterbilt 320...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
