Small storage tank?
   / Small storage tank? #1
Slippy
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
Read a lot about cons of storing fuel. Has anyone seen a say 20 to 30 gallon storage tank that has a pump built in? Biggest problem with 5 gallon cans for me is lifting them up on top of the tractor and then not spilling it all over the place. Any ideas? I was going to get a 55 gallon drum and fill it about 1/2 and put hand pump on it, but a drum that size can be difficult to move from the truck to the floor, etc.
   / Small storage tank? #2
I have a 30 gallon poly barrel I plan to use for that purpose soon. I have a hand pump and as soon as I clean out the drum, I'll be putting it together.
Where would one find such a barrel. 30 gal sounds about right.
   / Small storage tank? #4
Todd makes a Diesel Caddy. Click Here
Checked EBay. There is one for $315 in Buy It Now. /forums/images/graemlins/blush.gif
My back is not that sore yet. /forums/images/graemlins/tongue.gif
   / Small storage tank? #5
Slippy,
In Columbus, there is a recycler of drums/barrels. Container Management Company near I-71 and 5th Ave. Cost me $26.00 +tax. I have the phone number if you'd like via PM.
Jerry: Thanks. They are on Corrugated Way and I got their number. Will call them tomorrow. Thanks again.
   / Small storage tank? #7
</font><font color="blue" class="small">( Read a lot about cons of storing fuel. Has anyone seen a say 20 to 30 gallon storage tank that has a pump built in? Biggest problem with 5 gallon cans for me is lifting them up on top of the tractor and then not spilling it all over the place. Any ideas? I was going to get a 55 gallon drum and fill it about 1/2 and put hand pump on it, but a drum that size can be difficult to move from the truck to the floor, etc. )</font>
I'd suggest about 100 gallon tank to be useful. You can use your FEL to hoist it full up to the top os a frame you'll build so that it can refuel all your diesel powered equipment via gravity flow. If you have a diesel truck and tractor, and maybe even a generator; you can supply all from one storage tank. You can get the stabilizer additive from marine stores if you think water and bateria are a problem.
Suitable tanks can sometimes be had from furnace supply stores, get one made to hold fuel oil, Furnace oil #2 and #2 diesel are the same thing, so all the fittings are fine.
Pat
I do have an old fuel oil tank. Will it work? Has been sitting for about 10 years. Best way to clean it out?
   / Small storage tank? #9
</font><font color="blue" class="small">( I have the phone number if you'd like via PM. )</font>
Please PM me the number.
Thanks.
   / Small storage tank? #10
</font><font color="blue" class="small">( I have a 30 gallon poly barrel I plan to use for that purpose soon. I have a hand pump and as soon as I clean out the drum, I'll be putting it together. )</font>
I'm looking for a 12 15 18 or 20 gallon container.
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
2013 John Deere 650K LGP (A47477)
2013 John Deere...
2019 Ford F-150 Crew Cab 4X4 Pickup Truck (A53422)
2019 Ford F-150...
2017 VOLVO VNL TANDEM AXLE SLEEPER (A54313)
2017 VOLVO VNL...
2015 FREIGHTLINER CASCADIA DAYCAB (A53843)
2015 FREIGHTLINER...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A54607)
2007 PETERBILT 379...
