Small Running Gear Trailers
/ Small Running Gear Trailers #12
jmessing said:
Hi. It's been a while since I visited. I now have a second need for a movable chicken coop. I'm leaning toward the FarmTek running gear. They have two models rated at 1500 and 3000 pounds. I plan to build a coop on the 3000 and to buy the 1500 with a expanded wire deck for moving materials. No dumping capability, but I think I can live with that.
Joe
Different trailer for different jobs...:D
Here is their dump trailer...
Utility Trailers - FarmTek
/ Small Running Gear Trailers #13
Here are the 2 ton models from CMI. It looks like they tilt up pretty high so I don't know if that solves the problem that Bob has had with dumping.
Country Manufacturing, Inc. - 2-Ton Utility Wagon & Tandem Axle Trailer
Paul, the utility trailers at FarmTek look just like the CMI ones.
Lunk, the KK trailer looks good, I like that it is all metal, but, for me its capacity is too low, especially at that price which is up there.
I've looked around for a while now and cannot find anything in the 2 ton range that looks like it would meet my needs except for the CMI ones. And the price is good. I've got rear remotes so I would add a ram and not have to mess with a bottle jack.
/ Small Running Gear Trailers #14
I've had good luck with the Country Manufacturing 2 ton trailer. The wood floor doesn't leak as much as you'd think. It is a little worse for wear after we abused it during my Pool Demo Project but has stood up pretty well. It dumps plenty high - everything slides out OK. The rear could be higher when dumping - the piles end up kind of long & low.
Here is the assembly process with pix CMI 2 ton trailer
/ Small Running Gear Trailers #15
There is one thing I don't understand and that's the drop-pin hitch connection. I just don't see how that is supposed to work on a regular draw bar. I see no problems on level ground. But what about hills and uneven ground side to side? With a ball hitch the trailer can move up and down and twist side to side by rotating on the ball. On the wagon version the tongue is hinged to provide up and down flexibility. I just don't see how it works on the trailer. Is there just a lot of slop between the pin and the draw bar hole it fits in?
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2019 Ford F-150 (A60462)
2019 Ford F-150...
2021 FORD RANGER (A60736)
2021 FORD RANGER...
John Deere 6125R (A60462)
John Deere 6125R...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
