Small red triangle on tach???
   / Small red triangle on tach??? #1
kwg
Addison WI
2012 Kiotie CK35 HST
What is the the small red triangle on the tach for? Is that the max rpm or the rpm that should be used with implements?
   / Small red triangle on tach??? #2
It is the RPM you need to set the engine to run a PTO driven implement to make that PTO shaft turn at 540 RPM. Most PTO driven implements were designed to be run at 540 RPM. Not saying you cant run them a little slower, and I often do for various reasons.
James K0UA
Thanks.......I just got the tractor and don't want to screw anything up....:ashamed:
   / Small red triangle on tach??? #4
Best practice it to throttle down to idle speed then engage the PTO for your shaft driven implement, then throttle up to the 540 mark (depending on your tractor that could be anywhere from 2200 to close to 3000 rpm) and then got to work with your implement. When you want to stop, slowly throttle down, then disengage your PTO control. There are many different ways to engage the PTO, read your manual, some use the clutch, others are electrical/hydraulic etc. Let us know if we can help in any way.
James K0UA
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
New Holland T5060 Tractor (RIDE AND DRIVE) (A50774)
New Holland T5060...
2017 JCB 3TS-8T TELEKSKID SKID STEER (A51242)
2017 JCB 3TS-8T...
2015 Polaris Sportsman 570 SP ATV (A50514)
2015 Polaris...
John Deere 960 Culitivator (A50514)
John Deere 960...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
