Small hydraulic-powered chipper/shredder?
   / Small hydraulic-powered chipper/shredder? #1
davesisk
Platinum Member
Raleigh, NC USA
Massey-Ferguson MF 1220
Anyone know how to build one? Or where to buy one cheap? Anyone willing to build one for me? I have a Power-trac 1418 with hydraulic remotes, and I could really use a small, inexpensive chipper/shredder that I could carry or tow with, and power off of, the Power-trac. Something like the 5HP gasoline powered type, but with a hydraulic motor to run it instead of a gasoline engine.
Please post any ideas!
Regards,
Dave
   / Small hydraulic-powered chipper/shredder? #2
Heat is the problem with running a motor off a remote. You can cook (ruin the seals) a transmission fast. Even if you have the flow, unless you have the other prerequisites such as a large hydraulic fluid tank and/or cooler you're running a risk.
If you haven't already checked with the manufacturer, that's the first thing to do. With a Power-trac, you might be able to do it. With most small and medium tractors, it's a no no. If Power-trac gives you the go ahead, I'd still add a transmssion fluid temperature gauge. I think you're limited to the low 200 degrees to prevent damage.
Thanks for the post, Darren. I will check with Power-trac first, but I think it should be fine. Power-trac makes attachments such as a hydraulic stump grinder (which I have), a hydraulic power-auger (which I have), a hydraulic tiller, hydraulic trencher, etc. I thinking that a hydraulic chipper/shredder would be very similar to the hydraulic stump grinder in it's operating characteristics (assuming it uses a very similar hydraulic motor).
If you're interested see www.power-trac.com for details on newer models, or see www.ipass.net/~davesisk/tractor.htm for my old model.
Dave
Oh, and btw, it actually uses 10 gallons of 10W40 motor oil as the hydraulic fluid...
Dave
2020 DRAGON ESP...
2015 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A56858)
2015 Chevrolet...
2016 Case CX55B (A55973)
2016 Case CX55B...
John Deere HD300 Sprayer Attachment (A56857)
John Deere HD300...
2021 SAVANA 4500 BOX TRUCK (A57880)
2021 SAVANA 4500...
2014 BMW X1 S Drive 28I (A56859)
2014 BMW X1 S...
