small complaint
/ small complaint #1
cjw
Winchester, VA
MAHINDRA 3510
I needed to clean the radiator screen on my tractor & discovered I needed to remove the loader to get the screen off all the way. The loader was surprisingly easy to remove.
Here is a picture of my 2800 without the loader.
/ small complaint
here is a picture from a different angle
/ small complaint #3
I'm sure your method is more "complete" - but I use compressed air to blow out the radiator screen on my 4110. Been a while since I've been near a 2810 so I'm not sure on the clearances and such, but it seems like you may be able to do the same thing so you don't have to remove your FEL. Granted, it takes me a little stretching & contorting /forums/images/graemlins/crazy.gif, but only takes a few minutes. Perhaps you can get an extended “wand” so you wouldn’t have to contort so much. (Hey, maybe I’ll do that too instead of using the short version I currently have! /forums/images/graemlins/tongue.gif)
/ small complaint #4
That sure is a good-looking tractor without the loader on it /forums/images/graemlins/smirk.gif
Mark
/ small complaint #5
I second your complaint! That is one of the few things I've found that I consider a true design flaw - they could have easily made the screen slide straight up for removal instead of to the side.
I am glad to hear the FEL was easy to remove. I've been thinking about removing mine just to reduce the weight for mowing around my yard and make it easier to maneuver around my wooded areas.
/ small complaint #6
<font color="blue">they could have easily made the screen slide straight up for removal instead of to the side. </font>
Help me understand here - are you saying you have to remove your FEL to remove your side panels or am I just misunderstanding what you are saying?
/ small complaint #7
The side panels will come off with the FEL attached - it's the screen in front of the radiator that won't slide out with the FEL attached. It will slide out about six inches and then hits the arm on the FEL.
Your extended wand idea should work.
/ small complaint #8
</font><font color="blue" class="small">( The side panels will come off with the FEL attached - it's the screen in front of the radiator that won't slide out with the FEL attached. It will slide out about six inches and then hits the arm on the Fel. )</font>
Just raise the loader to where the screen will come out !!
/ small complaint #9
</font><font color="blue" class="small">( Just raise the loader to where the screen will come out !! )</font>
Never never get under a raised loader or any of its components!!!! I refer to this link and other stories......
Mark
/ small complaint #10
My DK 35 is the same way.
The screen hits the loader arm.
When I need to clean the screen I lift the loader to where the screen can come out reach under the arm and pull out the screen.
You are not working under the loader and if the loader would fall your arm and hand has plenty of roon under the arms as not to get pinched !
/ small complaint #11
</font><font color="blue" class="small">( your arm and hand has plenty of roon under the arms as not to get pinched ! )</font>
Good! You are too valuable to the users of this website to lose /forums/images/graemlins/smile.gif !
Mark
/ small complaint #12
Thanks for that Mark /forums/images/graemlins/smile.gif
I work around heavy equipment every day. So I do know not to get under raised booms or truck dump bodys without blocking.
I've heard of accidents in our area and seen to many safty videos where the unthinkable did happen !!
/ small complaint #13
Its not the arm that raises and lowers the bucket that is in the way - its the fixed support arm that extends from the center of the tractor to the front. The only way to get around it is to detach the FEL.
Anyway, I removed the loader last week for the first time. I've had the tractor for a year and use the FEL regularly but not as often lately since most of the major clearing is done. I was surprised at how much easier it is to manuever and see while mowing without the FEL. If it goes back on as easy as it comes off, I'll probably remove it for mowing - which is now the primary use for the tractor.
/ small complaint #14
OK.
I see a lot of tractors and FELS with that support on.
I never gave it a thought about them being in the way for cleaning the screen.
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
2007 DRAGON  130BBL VACUUM TRAILER (A65643)
2007 DRAGON...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
CAT 225BLC Excavator (A65579)
CAT 225BLC...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2021 Sol Grand Design BK390 Camper (A62613)
2021 Sol Grand...
