Loader Slow pump response on start up
/ Slow pump response on start up #1
Elbill
Bryson City, NC
Kubota L3830
Seems like I have an intermittent problem with my L3830. Some times I get a slow 5-10 sec delay in hydraulic pump action after a cold start up( cold being first start up of the day. I hear a groan and then all is fine. No loss of fluid, odor,poor response after initial problem, no warning lights. Fluid is UDT and new, filters changed. Have a loader on it. Seems like pump is starving or some relief valve is stuck ? Too many things to run down- any thoughts?
/ Slow pump response on start up #2
It sounds like there is a suction leak in the pump supply side and you are losing prime. Did you have the problem before the fluid change?
Yes this problem has been with me for a while. I had changed fluids and the pump problem was more pronounced with non UDT so I went back to it. I think that a suction leak could be what I need to check out. Thanks
/ Slow pump response on start up #4
I recall reading about just that- suction leaks, on other posts for Kubota tractors. A rubber return hose was causing the problem. Easy to fix, if that's it. No indication of the leak, since it is a non-pressurized return line. Good luck!
Hope it is- I do not see any leakage from the hose on the ground under the tractor when it is shut off.
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
New/Unused Landhonor 78in Rock Bucket with Teeth (A65583)
New/Unused...
1999 Nabors Chip Trailer (A62613)
1999 Nabors Chip...
Hutchinson Grain Auger (A64127)
Hutchinson Grain...
