Slow Power Steering
/ Slow Power Steering #1
strum456
Platinum Member
Westmoreland County PA
Fords
2 of my tractors have what I would call slow power steering. The steering assist works, but if you try to turn the wheel fast, there is a lot of resistance. RPMs don't seem to affect the 841 (you could run it wide open and the steering doesn't work any better). Running the engine faster does help the 4610. Both tractors have Traviller UTF in the power steering. Both tractors have been flushed and new fluid added. The 4610 has had a new filter installed.
I am thinking that the UTF is too viscous to be used as power steering fluid. I was thinking of trying a thinner fluid, but I don't know what to try.
/ Slow Power Steering #2
I have a Case that uses Type F automatic transmission fluid and warns that Type A will make it spongy and soft . In fact it uses the Type F in the hydraulic drive and loader. I bought mine from Rural King ,a farm store in Indiana / Illinois .
/ Slow Power Steering #3
utf is fine for a ford power steering of that era, however them old pumps will run on atf fluid as well.
Can you think of any other reason why I would need to "wait" for the power steering to keep up with a fast turn? It gets worse when it's cold out, so I was thinking it is a viscosity issue. I thought of trying ATF in my 841 because the pump on it is off of a 1977 Ford Truck. I think those actually call for ATF, but I didn't know if the ATF would cause a problem for the steering box on the tractor.
/ Slow Power Steering #5
ATF will be fine.
SPEECO QUICK HITCH (A62130)
SPEECO QUICK HITCH...
Hustler Super Z 72in. Zero Turn Commercial Mower (A61567)
Hustler Super Z...
8062 (A61166)
8062 (A61166)
1989 Ford F600 Dump Truck, VIN # 1FDNK64P1KVA00407 (A61165)
1989 Ford F600...
STORAGE FEES (A59910)
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A62131)
UNUSED WOLVERINE...
