Slow Power Steering
/ Slow Power Steering #1
strum456
Westmoreland County PA
Fords
2 of my tractors have what I would call slow power steering. The steering assist works, but if you try to turn the wheel fast, there is a lot of resistance. RPMs don't seem to affect the 841 (you could run it wide open and the steering doesn't work any better). Running the engine faster does help the 4610. Both tractors have Traviller UTF in the power steering. Both tractors have been flushed and new fluid added. The 4610 has had a new filter installed.
I am thinking that the UTF is too viscous to be used as power steering fluid. I was thinking of trying a thinner fluid, but I don't know what to try.
/ Slow Power Steering #2
I have a Case that uses Type F automatic transmission fluid and warns that Type A will make it spongy and soft . In fact it uses the Type F in the hydraulic drive and loader. I bought mine from Rural King ,a farm store in Indiana / Illinois .
/ Slow Power Steering #3
utf is fine for a ford power steering of that era, however them old pumps will run on atf fluid as well.
Can you think of any other reason why I would need to "wait" for the power steering to keep up with a fast turn? It gets worse when it's cold out, so I was thinking it is a viscosity issue. I thought of trying ATF in my 841 because the pump on it is off of a 1977 Ford Truck. I think those actually call for ATF, but I didn't know if the ATF would cause a problem for the steering box on the tractor.
/ Slow Power Steering #5
ATF will be fine.
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
2017 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2017 Volvo VNL 760...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
UNUSED JCT 84" SNOW PUSHER (A62131)
UNUSED JCT 84"...
2018 Bomag BC572 Articulated Refuse Compactor (A61567)
2018 Bomag BC572...
207279 (A52708)
207279 (A52708)
