Slow Initial Steering Response (Hydro)
   / Slow Initial Steering Response (Hydro) #12
Mark
i just keep looking on the WWW until I stumbled onto a 6530 parts catalog. I've attempted unsuccessfully to stumble on that parts catalog again.
Sorry,Jim
Mark
Sorry,Jim
I had one bookmarked on my computer that worked for me before. I tried it and a blank screen with a sorry bout dat sorta excuse appears......so the comments on here about Branson removing it are true. That's a damnnnnnn stupid thing to do (opinion of a 2 tractor owner). Customer support has been my main gripe about this company from day 1. I thought that when TYM took over things would change but not so. Dealers are not the problem. It's the top brass. Why remove the parts list. Why should a customer try to verbiagealize the part he wanted to a dealer's parts clerk over the phone not knowing what to call the thing he wanted, or where it appeared in the parts breakdown, or whether a gasket came with the part or you had to order the gasket separately and all that crap when an online parts breakdown available to the general public would allow the customer to find what he needed, get the part number and go to the dealer of his choice and order the part.............where else would a Branson unique part like I am needing be purchased but from an accommodating Branson dealer!!!!!!!
I hope this rant finds it's way to the big boys and they fix this dumb blunder!
I got some help on here for a part list, located the part, ordered the part Nov 11, got it today, $22 bucks for the fluid feed adapter from the tank outlet pipe to the two pump inlets, a neoprene hose looking like the letter F. Not bad for a 12 year old Korean built tractor that isn't main stream. Good place for my problem as it was leaking and allowing the pump to suck air. Will install tomorrow.
Installed the part today. Took about 20 minutes. Bled the system and all my hydraulics work like new.....no telling how long this hose has been cracking. Other neat thing is that the hydro whine that I had bee putting up, developed on it's own, don't remember how long ago, is gone.......�� There was some oil residue around the bottom of the pump whereas the rest of the engine was dry. I should have picked up on that clue....but it has been quite awhile since I had the hood up and the side panels off.
So, to you guys that said suction side leak, you were dead-nuts-on. Many thanks.
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2006 KOMATSU D41P-6 CRAWLER DOZER (A51222)
2006 KOMATSU...
1264 (A50490)
1264 (A50490)
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2011 Liebherr L586 (A51039)
2011 Liebherr L586...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
