Sloppy Loader Control
/ Sloppy Loader Control #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
The loader Control on our Landtrac is sloppy, but still works. Could it be the linkage or will it be the valves? Will it be simpler/cheaper to replace the control or repair the valves? Is the control on a Landtrac going to be an orphan?
/ Sloppy Loader Control #2
Linkage is most likely cause for sloppy feeling.
Other possible item is centering spring mechanism is getting gummed up so not functioning properly but that typically causes unwanted function movement.
/ Sloppy Loader Control #3
I talked in another thread here about getting air into the cylinders because of the way I left the machine after use, and fixing it by parking differently. Could it be that?
