Backhoe sloppy backhoe lever
/ sloppy backhoe lever #1
trouble11
Plattsburgh NY
Kubota B9200
I have a B9200hst with a 4530L backhoe (same as a woods 750-2). The lever for the backhoe curl Twists when You are using it. I replaced the swivel joints but it still twists. This creates a problem because with it twisting You don,t get the action You were hopeing for with the bucket. Thank You all so much.
Jeff
/ sloppy backhoe lever #2
On mine I occasionally have to tighten the bolts that connect the arm to the control valve. When they get too loose they allow it to swivel around. I also did not care for how the rain would get into my controls so I cut our some heavy rubber and placed it over the control levers an against the cover to seal the opening. I do not recall the model of my backhoe but it is the under mount frame on my l2550.
On a side note, have you ever found yourself pulling harder on the lever when the digging is tough? I think somehow it allows more hydraulic pressure to pass through when it opened hard against the stop. :)
repete, thank you, I will check it out in the morning.
2006 Chevrolet C5500 Service Truck, VIN # 1GBE5E3256F423684 (A65563)
2006 Chevrolet...
1998 Reids 20' Lowboy Trailer (A62613)
1998 Reids 20'...
(4) Tractor Wheel Weights (A65640)
(4) Tractor Wheel...
Hedge Posts (A65640)
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2005 International 9200 Semi Truck (A66285)
2005 International...
