Sloping grade
/ Sloping grade #1
Michael Aos
Colorado Springs
Kubota BX2370-1 RTV500
I want to create a an angled slope from the house (high) to the backyard (low).
I've been gravitating toward a box blade, but curious if that's the right tool or best tool?
Kubota BX2370-1, but I'd consider moving to a new B2601 with 3pt position control if it would make the task significantly easier.
/ Sloping grade #2
A photo would help a lot. Where is the dirt source?
Bruce
/ Sloping grade #3
Like Bruce asks a pic would help.
Info on ground also, sandy, rocky, grass ext.
/ Sloping grade
Current soil is very sandy.
I would have fill delivered -- secondary question is what type?
/ Sloping grade #5
Never mind, I remember a lot about your situation with your BX and 3 properties
I would say in your situation a box blade with ripper bars and a FEL should do you fine.
you could also go the route of a tooth bar for the bucket and a land plane, both of those set ups would work.
A box blade digs more than a land plane but a land plane is better on loosely packed material and is faster and easier smoothing out, it just won't cut as well.
/ Sloping grade #7
I have watched guys on both Bobcats and dozers that were wizards at smoothing and prepping a yard. They could do in an hour what it would take me days to do, less well, with any tractor implement. JMHO.
/ Sloping grade
The main area I'm looking at is about 100' x 120' = 12K square feet. Plus maybe another ~4K square feet in front, and a couple thousand square feet on the 3rd property.
No hurry at all. Would also consider a 4-in-1 bucket if that's the best tool for the job.
/ Sloping grade
I might be able to borrow my dads Bobcat for a while.
I'd have to get a trailer for it, and about 17hrs drive each way.
/ Sloping grade #10
I would consult with your tractor dealer for an opinion if a new tractor operator can move dirt on your slope SAFELY.
Box Blades take longer to learn to use well than almost any other Three Point Hitch implement; only a moldboard plow requires longer hours.
Revising a slope grade is pretty difficult.
With SANDY soil you may just be able to accomplish this work with a B. I would consult with the Kubota dealer to match your local condition to the heaviest Box Blade a little 'B' will pull.
You will find getting your slope at the angle you want a challenge. Have straw handy to ****** erosion in case of rain.
I recommended a Ratchet Rake in another of your threads. I maintain that recommendation. It is much easier to smooth and finish grade with a Ratchet Rake for an inexperienced operator.
/ Sloping grade #11
I would have fill delivered -- second question is ~~ what type?
As a general answer, match what is 'native' to your area.
Colorado Springs is pretty dry, isn't it? Are you planning to grow prairie grass on the slope, or something that will require irrigation? Do you have any water restrictions in Colorado Springs? Composition of your fill should be to support verdure which will prevent erosion.
/ Sloping grade #12
Delivered fill, no digging. Set up lines of grade stakes and use your bucket. Start at the top at desired grade level and work your way down the slope at grade. (End dump & push over) it's important to keep a proper smooth grade as your working downhill. The slope stakes will be a big help. Flagging tied at desired height is more visible.
/ Sloping grade #13
At $1.00 per mile pulling a trailer and two round trips totaling 68 hours, what will be your cost? You can likely hire out this work cheaper than you can transport the Bobcat.
Skid Steers and tractors are both earth movers. Skid Steer work is primarily at the front, tractor work is primarily at the rear.
/ Sloping grade
That was my gut feel as well.
/ Sloping grade
I'd like to ultimately Xeriscape everything.
I need to address a "nagative grade" area, and then encourage any water to flow away from the structures.
1&2 are a little too flat. Backyard at #3 was left too flat by landscaping contractors we hired years ago.
/ Sloping grade
I spent Saturday pulling some stumps, clothesline poles, and removing a small raised garden. I spread the garden in some of the low spots (and holes) and smoothed it out with the bucket in "float".
I was pretty happy with the result, but I was thinking about that Ratchet Rake.
I don't even know how much I don't know about this stuff.
Just playing in the dirt.
/ Sloping grade #17
Ask questions.
Responces to specific questions, rather than broad topics, will be most valuable to you.
Only a few here grew up on farms with tractors. Most of us, like you, started at "0".
/ Sloping grade #18
Pictures of this area?
/ Sloping grade #19
If you don't have pictures can you estimate how much dirt you need to spread?
/ Sloping grade #20
For 12,000 square feet that is dead level to start with you would need about 112 yards of dirt to build up a slope of .5%. That is enough to have decent drainage away from the buildings. With dirt delivered that would be a one day job for me including accurate grading and rolling/compacting. I would not recommend buying a tractor for such a small project. What ever you have now will significantly impact the calculations, need more information.
Keep your 2370 and use it to xeriscape after the grade work is done. You will have less need for a tractor afterwards. As far as the fill is concerned I would look for something that has fines without large rocks. Tailings would work well if fine enough and depending on what is available close by sandy soil that will spread evenly will work too. Since this will be covered up with landscape cloth and covered with clean rock you don't need a high end topsoil. Tailings that were excavated from deep below the surface are rather sterile in most cases and wont grow much of anything. That includes weeds so this can be an advantage in for your use. Lowers the maintenance and weeds in your xeriscape.
2022 EZ-GO ELITE...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
20' CONNEX BOX (A65643)
20' CONNEX BOX...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
2006 Kenworth W900 Day Cab Truck, VIN # 1XKWDB9X76J112716 (A65563)
2006 Kenworth W900...
