Slip clutch
/ Slip clutch #1
MikeD
New Hampshire
B2910
I have a Bush Hog tiller model RTS50 which does not have a slip clutch. I contacted the dealer to see about putting a slip clutch on the drive line as I broke a tine hitting a rock. /forums/images/graemlins/frown.gif In New England we specialize in rock production. At first the dealer thought the cost would be about $100. Now Bush Hog is telling them I need a new drive line with the slip clutch as part of the drive line at a cost of $250. Can a generic slip clutch be added to a drive line? Does anyone have any cost effective suggestions on slip clutches? Thanks for any help on this. Mike
/ Slip clutch #2
Not sure on your particular model of bush hog, but on all of the others I have seen/dealt with you can add the slip clutch into the drive line. The slip clutch does add about 6 inches or so to the drive line length, so in a worst case scenario you might have to cut 6 inches or so out of the driveline to compensate if your slip joint in your drive line would bottom out with the slip clutch installed.
/ Slip clutch #3
Agri-Supply has slip clutches for $62.49 (part # 32323). Several TBN'ers have used them. You will probably have to cut the PTO shaft shorter. Do a search on TBN for the instructions.
Agri Supply web site - ask for a catalog
/ Slip clutch #4
The Pto shaft for my brush cutter is too short because of the quick hitch. If the slip clutch adds 6 inches it will be just right. Does anyone have an actual measurement from bolt hole to bolt hole on this clutch?
/ Slip clutch
Thanks Mad. I just ordered the part from Agrisupply. On another note I have yet to paint the dethatcher due to the cold weather. Once the temps get up to 50 I will get that done and send you a picture of your creation. Thanks again for a job well done. Mike
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
207281 (A52708)
207281 (A52708)
4 Shelf Rolling Cart 6ft x 3ft (A61165)
4 Shelf Rolling...
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A60352)
2025 Wolverine...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
2020 CAT 239D3 Compact Track Loader (A61166)
2020 CAT 239D3...
