slip clutch
/ slip clutch #1
ebeacham
Southport NC
TYM 723
Since I now know ( with the help of you guys ) that I need a 1 3/8 smooth slip clutch for my KK brush hog; Where is the best place to get/order one? Are there different qualities? /forums/images/graemlins/confused.gif
/ slip clutch #2
</font><font color="blue" class="small">( Are there different qualities? )</font>
Hi Eric,
The most popular 2-plate is Eurocardan... most any farm store should carry this... TSC has it ~ $79-89... /forums/images/graemlins/smile.gif
I've been meaning to ask ya... What does " A bad man on a good tractor"... mean? /forums/images/graemlins/confused.gif
(No offense, but it kinda sounds like self-depreciation...) /forums/images/graemlins/crazy.gif
/ slip clutch #3
agri-supply is cheapest there they are the main distributor for what ever brand they have i forget which kind... a good bit cheaper than TSC's..
/ slip clutch #4
Agri-Supply sells the EuroCardan for around 57.00 plus shipping.
Rick
/ slip clutch #5
Somewhat related question:
I have been told that there is a spray lubricant to apply to a slip clutch to help it from seasing up. My dealer didnt know of such a product. I have had my slip clutch not slip once (and it stalled the tractor) and wanted to try to prevent this from happening again. Thanks /forums/images/graemlins/crazy.gif
/ slip clutch #6
Bob:
Perhaps you will have to adjust the spring settings to allow the clutch to slip.
Also; if you are running borderline horsepower, it may be difficult to adjust the clutch so that it will slip when required but hold under normal working conditions.
Egon
/ slip clutch #7
if the material on clutch is organic if you spray anything in it it will slip if it's metalic when it slips the oil/grease will most likely burn off. If organic it'll soak in and cause trouble..
With the plate off or seeing the edge if it has speckles of something looks like shiny spots it's metalic like diamonds..
Your suppose to loosen nuts and let the clutch slip to keep it from ceasing up on you..
then tighten it back..
/ slip clutch
It means that my tractor is way more capable than I am /forums/images/graemlins/grin.gif
/ slip clutch
Thanks,
Ordered it today from agri supply!! /forums/images/graemlins/smile.gif
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
2022 Blue Diamond Brush Cutter (A64126)
2022 Blue Diamond...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2007 Hooper 20ft Equipment Trailer (A65563)
2007 Hooper 20ft...
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter (A65583)
New/Unused...
