slip clutch for brush hog
   / slip clutch for brush hog #1
ebeacham
Southport NC
TYM 723
Who makes and sells a slip clutch for a KK 6' brush hog?
What is a fair price for one?
   / slip clutch for brush hog #2
Are you looking for a slip clutch PTO to replace your current PTO or the add on clutch which uses your existing PTO (you may have to shorten your existing PTO to add on a clutch) Many tractor dealers carry the addon clutches, and I believe TSC and other "box stores" do as well.
   / slip clutch for brush hog #3
If you have a standard round bore shear 1/2" bolt grade 2, you will need to ask for a Round bore to Round bore 1 3/8" shaft 2 plate clutch but you will need to use grade 8 bolts or you will still have a sear bolt system.
   / slip clutch for brush hog #4
Tractor Supply Co. has them for around $95.
Like the others mentioned the PTO shaft will probably need to be shortened once installed.
   / slip clutch for brush hog #5
Ive seen them at TSC. dont know the price though. The only attachment i have a slip clutch on is my tiller. Everything else is shear bolts.
Larry
   / slip clutch for brush hog #6
Check out <A target="_blank" HREF=http://www.agri-supply.com/catmain/3500005.htm>This Link</A> to Agri Supply. Look at item number 32323. $56 something plus shipping.
   / slip clutch for brush hog #7
I got the TSC one for about $90. Yes! Shorten your PTO shaft. While a newbie, I had a bad break b/c I didn't shorten the shaft after installing it and tried raising the tiller a little farther than I didn't know was possible. <BANG!> I don't want to talk about it...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A57193)
UNUSED RAYTREE...
UNUSED FUTURE MINI EXCAVATOR RAKE (A57193)
UNUSED FUTURE MINI...
2016 Cat TL1055D Telehandler (A55315)
2016 Cat TL1055D...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
UNUSED FUTURE CL100 40" - 10" CLAMP GRABBER (A57193)
UNUSED FUTURE...
