Impaled
First off I have a very old, very homemade 6' cutter. It has what appears to be a Bush Hog brand gear box and frame that has been welded to a home made deck. It belonged to my grandfather and I have since re-comissioned it and used it seasonally for the past 7-8 years. This whole time I always assumed it had a shear bolt because you could see the yolk and how it appeared to be bolted to the input shaft just like every other cutter i have ever used or been around. Well, after prepping the cutter for paint, I discovered that the yolk and inputshaft for the cutter and splined, so there is no shear feature whatsoever for this cutter.
I am very lucky that I have not destroyed my pto shaft, or even worse my pto driveline inside my tractor.
I want to add a slip clutch to my cutter, but I can not find any kind of specifics on what size, type, or any info of the sort that will direct me on my purchace.
I know I want a clutch that has two bolts that pretty much clamp the female end of the clutch to the male end of the cutter, but I do not know what size clutch I need.
The majority of my cutting is pasture land, but I do have a tendancy to back over some pretty thick brush from time to time. Well actually more of a pretty regular basis. Like I said Ive been very lucky up to this point...
if anyone has any experience/advice that would be great!
