Slightly bent FEL - Problem?
/ Slightly bent FEL - Problem? #1
dharris894
NH, ME
Kubota L35
Hello. I am new to the forum but have been studying the posts. What a great source of info!
I am shopping for a 30-40 hp tractor with Loader and backhoe. I found a 1989 L3350 in good shape for $14,000.
However the loader is about an inch higher on one side than the other. I can't tell whats bent. Is it possible that this is something that can't be fixed and should be avoided?
Any other thoughts on this model?
/ Slightly bent FEL - Problem? #2
Did you check the tire pressure? That could affect the level somewhat I think.
Might be sprung and if so, I don't know how you would correct it.
Ron
/ Slightly bent FEL - Problem? #3
It can be a tire pressure differential; especially the rear tires or it can be that it's sprung and can be bent back into the proper place or it can be that it was installed incorrectly. When a loader is installed, all the parts, nuts, and bolts should be assembled loosely with the loader bucket sitting on a hard, level surface (concrete usually), and only after completing the assembly should they be tightened. In any case, I would expect it to be pretty easy to correct.
2019 CATERPILLAR 259D3 SKID STEER (A64279)
2019 CATERPILLAR...
2015 John Deere 8270R (A64119)
2015 John Deere...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
Toyota 2FGC20 4,000lb. Propane Forklift. (A61572)
Toyota 2FGC20...
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
2018 Takeuchi...
