Sleep apnea, CPAPs and other sleep health solutions.
   / Sleep apnea, CPAPs and other sleep health solutions. #121
   / Sleep apnea, CPAPs and other sleep health solutions. #122
Yes I have a S9 now. Someone here kindly sent s link so that I could download the clinical manual and get into the appropriate menus without making a mess of things.
My issue isn't with the mask but about once a week I end up sleeping with my mouth open for a while. When I wake up my mouth is thoroughly dried out and that makes me a bit growly. That the CPAP puts out more pressure to counter act this makes no sense at all.
I'm anticipating an interesting conversation with the clinician when I go get my new CPAP. The two times that they have set it up they made some stupid mistakes. The first time setup the CPAP wasn't set for auto pressure and would just blow at 17lbs all night long after the ramp up. The second time they set it up the auto pressure was enabled but the max pressure was set at 20. That was rather uncomfortable as well. When I got into the menu I set the lowest pressure right down to 4 and I would set it lower if I could. I set the max pressure at 14 which is considerably more comfortable. Like I say it'll be an interesting conversation.
Do you use a chin strap? I believe that it helps with the open mouth issue.
Getting a good technician to fit and tune your CPAP would be great, but not always something that is readily accessible...
Good luck!
All the best,
Peter
   / Sleep apnea, CPAPs and other sleep health solutions. #123
My neighbor has sleep apnea and since he is a restless sleeper, he has trouble using a CPAP machine. He is scheduled to have the Inspire implant surgery next month:
   / Sleep apnea, CPAPs and other sleep health solutions. #124
Your min/max pressure is very important. Many sleep apnea doctors are fine with and AHI of 10 and higher which is ridiculous. Your AHI should be between .5 and 2. I was using a min of 4 and max of 10 thanks to my doc, but I was seeing AHIs of 10 and higher. I was ripping my mask off in the middle of the night and not seeing any benefit from the cpap. Talking to a good friend of mine he looked at my sleep data using Oscar and could easily see I needed more pressure, so we slowly increased my min pressure and maxed out the max pressure. I now use a min of 18 and max of 20. My AHI is great now. It will take some getting used to but if you have severe apnea like I do, try it! You will sleep much better and fell much better the next day
New 4-235/80R16 Montreal Trailer Tires (A50774)
New 4-235/80R16...
John Deere 652R (A50121)
John Deere 652R...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
2021 New Holland C327 Compact Track Loader (A52748)
2021 New Holland...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
