Sled Trailer Build...
/ Sled Trailer Build... #1
RobJ
Elite Member
Spring, TX (Houston)
Kubota L2500
Think I posted about a sled trailer. Well the old one is sold (gone) and the new one has begun. It's a 14' sled type, 20.5x8.10" wheels/tires rated at C (1150# each). The axles are 3500 leafs but my max gross is 4600#. When the tires wear out maybe I'll move to D tires. I think they are 1500# each. The deck with is 90". Wide enough to load my ATV's side by side, and easier to slide sideways than a 6'6" trailer. All frame members are 5" channel (6.71# foot). So fas it's all scrap metal at $.25 a pound. Much cheaper than new. I know I will have to buy some more new unless the scrap yerd gets in some decent 2x2 angle. I need this to complete the side rails and other fun stuff.
It all started here at the yard, SSS Steel in Houston, Jenson location....
I borrowed my BIL 16' tandem and brought home the steel. 7 x 20' sections of the channel. Also bought 3 20' pieces if 1/4" 2x2 angle. I wish I would have picked up double of that. A little rough but a twisted wire brush cleaned it up. The channel looked new, almost no rust.
I used a Milwaukee 14" chop saw to cut it up and pile it under my wifes Suburban.
Once my 5x12 trailer sold we were off and running. I wanted a sled so we played with the axles being over slung or under slung. I thought I might have to go over but late research told me under would be fine. It was. Here we are just playing with the axles.
Here we are just laying out things. When I bought the stuff they were short 2 tires and 1 axle. So we did what we could in the mean time.
I precut 3 boards to size the width. Since the channel is wavy when it's long I used clamps to hold it tight while we squared it up.
I quick check told me the deck height is about 25" and the tire bump clearance is about 5". nice, I won't have to mess with the hangers or anything.
Next we (my 16yo son and I) welded the front and rear cross members to hold it square, couldn't weld the centers yet because we hadn't located the axles yet. Starting to look like something!!
Next pic is after some work on Saturday. I got the second axle and tires and we located the axle. Went with the standard 60/40 with the split at the equalizer. Boy getting the axles was a bit of a chore, longer than I thought. The springs want to flop down, hard to keep the W in position. My son suggested just sticking to a measurement once we get 1 in place and go from there. That worked perfect (he's smart and glad he'll be supporting me one day!!). I tacked up a couple more of the cross members and took it for a test spin. My wife drove while we were in the back. It did real nice. The axles are perfect except one was out 1/32". Good enough!. You can see how I spaced the beams, tightened them up near the axle. The front are on 2' centers, the back a little closer.
A couple more..
The axles and the W. On the bumps and stuff the equalizer works well.
On Sunday afternoon I got a few more hours to work in it. The deck is plywood going crossways. I left the 1/4" angle up a bit to slide the ply in from the rear. Then I only have to arrach it in the middle a couple places. I think this is going to be ok. In the end I have some more spare ply that I intend to run long ways. Two runners the width of my tractor wheels. Glued and screwed this will give me 1.5" of crossed up ply, should be plenty strong.
This about where I left it on Sunday, then some yard work to finish. The front side is all 1/4" 2" angle.
Here is the side rail. The angle covers the top part of the channel. Nice thing is once the ply is removed I can get the stick in there for a solid top weld. The lower side rail is more nice looking surplus. 1/4"x3" flat bar. I ran it down to the bottom of the channel. This left about a 1" gap. Not sure how I liked it at first but I'm ok with it now. Especially when I priced some 6" flat bar last week. Hmm about $6 for 8' vs. $18 if I recall. I'll be able to hook straps and stuff in the middle.
Just for grins I brought out my ATV ramps. The angle wasn't that bad on the 6' ramps. I'm thinking about a 7.5' ramp made from channel (heavy) but it'll hold the tractor and act as a drop in rear gate. The aluminum ramps are actually some scaffolding (about 10" wide and a channel). They might actually hold up the tractor seeing how the weight will shift from the tractor to the trailer. But I don't think I want to test it unless I have a stand under them. We'll see. When I moved the tractor I used SYP 2x10's with a cinder block unter them in the middle.
All for now!
Rob
/ Sled Trailer Build... #15
Nice, I looked at the first attachment before I read it and said to myself "that looks like the Triple S surplus yard", and it was. I've spent many a hour there.
Yep they are starting to reconize me there. I just wander around the surplus yard at lunch sometimes. Of course the real action is at the check out counter...:)
But I try and stay away from Saturday morning. On a nice day that can be a rat race with all the people there. Get there about 8 and it's not to bad.
Just about there!
/ Sled Trailer Build... #18
Nice looking trailer. You could use it to haul a tractor. Great job.
Can Am Defender (A63689)
Can Am Defender...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
8ft 3in Teakwood Live Edge Slab Table (A65583)
8ft 3in Teakwood...
Quick Attach Concrete Mixer (A65579)
Quick Attach...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
