skidsteer or compact tractor
/ skidsteer or compact tractor #1
chinawall
Can anyone tell me the pros and cons of using a skidsteer to till, blow snow, and bushhog instead of a compact tractor such as a Kubota 7800?
/ skidsteer or compact tractor #2
I can't think of any pros; cons would be soil compaction, tearing up the sod/ground cover with the skid steering, and expensive implements.
/ skidsteer or compact tractor #3
Biggest advantage for SS would be visibility. All attachments are in front of operator. Higher flow rate for hydraulics - if needed. Can turn in tighter area and more maneuverable.
/ skidsteer or compact tractor #4
Come to think of it, my brother has a form of HD brush cutter on his Bobcat he uses to clear in the woods. He says it's a beast, really does the job.
WHAT DOES BOBCAT 170 COST..BALLPARK?
/ skidsteer or compact tractor #7
you would be looking north of $22K depending on options you could get over 30k on the new side
/ skidsteer or compact tractor #8
Chinawall,depending on your application you could get into a 30 to 40hp. tractor with all the attachments you want for less than a new bobcat s175.I have always found a tractor more comfortable to use and the attachments are far less in price.You can always find deals on used 3pt. attachments.I sell bobcat and kioti tractors.Just my 2 cents.
my Kubota b7800 won't go near a thornbush without losing the calcium in the tires. That why I thought about a skidsteer
/ skidsteer or compact tractor #10
It's a great deal if you can afford both but if you can only choose one, I'd have a tractor. If for no other reason than every time we use a skidsteer around here when we're done I have to put the blade on the back of the tractor and straighten out the area the skidsteer tore up...
/ skidsteer or compact tractor #11
Chinawall,There are a couple company's that can foam fill your tires so you will never get a flat again.It's not cheap but if you already have the tractor this would save you alot of $.
Hey Kioti, where are these companies?
/ skidsteer or compact tractor #13
Call your local tire companies. If they don't do it, they should know who does, in your area. Equipment rental and tractor shops will know too.
/ skidsteer or compact tractor #14
What about a ToolCat to replace the skid steer AND the tractor. One set of implements, more expensive than a compact tractor, but cheaper than a skid steer.
DEWFPO
2025 78in Bucket Skid Steer Attachment (A61572)
2025 78in Bucket...
JOHN DEERE 325G SKID STEER (A64279)
JOHN DEERE 325G...
2021 Chevrolet Malibu Sedan (A61574)
2021 Chevrolet...
19ft Sailboat w/ 2018 Continental Trailer S/A Boat Trailer (A61574)
19ft Sailboat w/...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
2025 JMR Tree Boom Skid Steer Attachment (A61572)
2025 JMR Tree Boom...
