MF RED in MT
What I use is the Timber Tuff TMW-54 Log Grapple - 22" (A.K.A. poor mans grapple), but lately I just rotate these jaws 90 degrees, back up to the log, pick it up off of the ground then cut the log into 18" long rounds
A simple HF chain with the link style hooks on both ends will work fine as long as you can attach the chain to a higher anchor point on the 3 point hitch.
A simple 3 point quick hitch from HF with a chain link style hook welded in the center at the top will work.
Or you could get a similar setup already to skid your logs.
Here's a few links for you to check out and also my log skidding/raising system pic:
KC
Amazon.com : RJ Designs XHD 3 Point Log Skidder - Designed and Made in USA - Super Strength and Durability - Standard Model Without Log Chain : Garden & Outdoor
Amazon.com: Timber Tuff TMW-54 Log Grapple, 22": Garden & Outdoor
KC
