Skidder or Tractor? If you could only have one.
   / Skidder or Tractor? If you could only have one. #91
I'm on the skidsteer side.
I've been wanting a skidsteer for leveling dirt for 50 years.
I wouldn't even think about using the skid steer for that, even though I have all the necessary parts and adapters to run 3-point stuff on the skid steer.
For leveling dirt, gravel, etc. I much prefer using the tractor pulling one of these two.
If there's no real precision needed, either the snow pusher or my made-towable 3-point blade also works well. As does a box blade behind the tractor.
   / Skidder or Tractor? If you could only have one. #92
For basic loader work I find the tractor far more user friendly. Loading a dump trailer, for example, I can see where to put the next bucket load in the trailer.
The longer reach of the tractor's loader is also very helpful a lot of times, and especially when using pallet forks.
But my main complaint about the skid steer is the procedure required to get in and out of it. Gotta do the seatbelt and turn the hydraulics back on every time. Loading something on a flatbed can be quite complicated since if I want to get out and see exactly where things are, either the loader must by high enough or all the way down to be able to open the door.
With the tractor I can simply hop out and take a look, then get back in the seat without having to do anything special to continue. Plus, for the most part I can stay seated since I can see what's going on anyway.
You can do that with a skid steer too.
Yes, for the most part I could, just not nearly as efficiently. I thought I explained why in the post you quoted, but maybe not clearly?
   / Skidder or Tractor? If you could only have one. #93
For leveling dirt, gravel, etc. I much prefer using the tractor pulling one of these two. View attachment 3631584
Where I want to level, I don't have room for all that. Neither the backhoe or Little Kubota LX2610 fit well.
I'd never buy less than a 40 hp again. I find the LX2610 to be worthless.
My wife wanted me to have something that didn't need worked on. That only lasted until it needed serviced.
we should have bought older and bigger. Or smaller framed
Or just got a skid loader at that time. We were replacing a John Deere 400 garden tractor.
I.need to find a roving mechanic near Clifton, Illinois
I also have fill to dump over a foundation wall.
   / Skidder or Tractor? If you could only have one. #94
Like asking:
"If you could have only one screwdriver..."
"If you could have only one size socket..."
Bruce
Or only one woman!!🤪
   / Skidder or Tractor? If you could only have one. #95
I keep seeing it posted in this thread about not being able to get out of the skidsteer if the bucket or attachment is raised and while that may be true with some brands, but there are 2 brands that have overhead roll up doors and you can exit the cab no matter what the position of the loader arms. This was a must for me when I bought my skid steer, there is another brand that has side entry into the cab , so there are options out there to negate that point that continues to come up.
   / Skidder or Tractor? If you could only have one. #96
G'mornin.
I get asked when I will buy a skidder, usually by skidder folk. I say never and that I don't need one cuz of my tractor w/FEL and they look confused. Or wounded?
While I realize that seeing the cutting edge would be a huge advantage, I feel that a tractor is far better for rural living.
Your opinions??
I thought about this quite a lot, and I have concluded that I could make use of a skid steer versus one of my tractors. When purchasing my second I thought about the skid steer and was encouraged by my wife among others, but like everyone here seems to say I thought Tractor was more appropriate to our role living. But since I do have two machines I think would be a skid steer I think gives me the best of both worlds
So, my rationale is that I already have a small tractor. The skid steer would be big enough to take over duties of the bigger tractor and give me the best of both worlds.
Why do I like the skidsteer.? It’s got a higher lifting capability for loading trucks. It’s got a more visibility to the front. The way is designed it can turn literally on a dime. The hoe attachment as far as I can tell will do everything the backhoe on my bigger tractor does plus you can actually raise the lift arms and dig higher up on a bank or over a wall, etc.
I believe the hydraulics on the skid steers that I’ve seen are superior to ones on my green machines and can operate front hydraulic equipment better.
By the way, those of us in the industry, (I’m associated with Cummins and others) are pretty clear what a skidsteer is.
   / Skidder or Tractor? If you could only have one. #97
As mentioned earlier, in my case the tractor lifts higher, plus it allows me to see where the load ends up when using a dump trailer.
For a small field of view, yes the skid steer does offer better visibility up close. With the tractor I can see 360, it has usable mirrors, and only the hood can really hide anything. If I forget what I drove up to, I deserve to run into it.
I'd give the tractor an A for visibility and the skid steer a D-.
   / Skidder or Tractor? If you could only have one. #98
If the bucket is partially up such as loading stuff in a truck bed, your still stuck with crawling out under the loader arm (dangerous) or over the loader arm. With a tractor your mounting and dismounting does not change regardless of were the loader is. My experience is mostly in open station skid steers. You do bring up a good point regarding cabbed skidsteers.
SOFTBALL & BASEBALL HITTING & CATCHING GEAR (A58374)
SOFTBALL &...
2016 CATERPILLAR 236D SKID STEER (A52709)
2016 CATERPILLAR...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
KING KUTTER 5' DISC BLADE W/ 1PT HITCH (A52708)
KING KUTTER 5'...
16001 (A55853)
16001 (A55853)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
