skid steer ripper parts
   / skid steer ripper parts #1
johndeerefarmer
Texas
Deere 6105R, Deere 620, Deere 340G, Deere 329D
Hi,
I want to build a ripper for my skid steer. I would like to use parts similar to these.
Hay King Renovators - Hay King - Miller
Any one have a source for parts like that?
Most that I see look like they use the shanks off of a box blade. That would work but a box blade has nothing to trip or break if you hit something big. It looks like the pasture renovator shank has a bolt that would break so it could swivel and not break something.
Thanks
   / skid steer ripper parts #2
If you use the type of scarfier that has a series of holes for depth control, you could do something similar:
Google Image Result for https://cdn3.volusion.com/wf72e.9ho5t/v/vspfiles/photos/ETA-CMPBB-3HOLE-SHANK-PR-3.jpg
Upper hole for pivot axle
Lower hole with bushing to step down ID for smaller shear bolt.
Handful of extra shear bolts, wrenches, and a punch in the tractor toolbox.
Thanks. What I really need is the part that the tooth mounts too. I don't know what you call it but it would clamp to the tool bar and I would mount the ripper tooth to it
   / skid steer ripper parts #4
Those mounts are pretty basic fabrications for someone equipped to build attachments. OEM parts priced as they are, even a local welder might be cheaper if you have a good sketch.
I will take a look. Thanks!
   / skid steer ripper parts #7
what are you trying to do ? if you have more than a couple and trying to go very deep you will not have the necessary traction from a skid steer
   / skid steer ripper parts #8
Whats the relief valve pressure on your skid steers dump circuit ? I would design the ripper to exceed the relief valve in strength.
Break up dirt so I can move it, level ground,etc. Dirt is too hard to dig easily with just the bucket. I could get teeth for the bucket I guess
   / skid steer ripper parts #10
if you have the right kind if bucket and a smaller Skid Steer you can get away with a tooth bar they are relatively affordable - if you have a bigger machine you need a welded tooth bucket with the replaceable tips, i love mine!!!! it will dig up pretty much anything i want to dig up - we have red and gray clay here - if you dont knwo what gray clay is, its the hardest thing i have ever dug in, may was well be concrete and it will sharpen your tips up as well!!!
you will do a great job of breaking up things iwth the skid steer with a tooth bucket - if you live in an area that has better soils they work even better
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53472)
GALAXY - SET OF...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2015 Ford F-450 Service Truck, VIN # 1FDUF4GT7FEC15731 (A51572)
2015 Ford F-450...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
