skid steer quick attach or not?
   / skid steer quick attach or not? #1
coldfingers
Warren, Mn.
2013 Kubota RTVX-1120D, kubota ZG 227, kubota LX 2610
Looking at a 4r series tractor, those of you that have loaders on 3 or 4 series tractors, do you like the skid steer quick attach over the pin on attachments?
Thanks.
   / skid steer quick attach or not? #2
I had pin on bucket on my tractor for years, and regretted it ever since purchasing. Several years ago, I switched to a SSQA system. It's been great. I actually use forks and a forestry grapple n my loader now.
BTW, I like the true SSQA better than the JD proprietary quick attach system. My neighbor has the JD system on his tractor, and as a result, we cannot share attachments. The SSQA is more universal, so a greater chance you can swap equipment between other tractors.
   / skid steer quick attach or not? #3
What John said.
Don't buy a new FEL without it.
   / skid steer quick attach or not? #4
JD does not even offer a "pin-on" option in the larger tractors, so your choice is the JDQA, SSQA, or the euro/global carriers.
In a 4-series, I agree that SSQA is the best option, but for 3-series and smaller I think the JDQA is the best.
   / skid steer quick attach or not? #5
A loader without QA is like a truck with the doors welded shut. Don’t buy it any other way. The JDQA is probably better in the application it’s used than SSQA but the pool of available implements for SSQA is a lot bigger. I would go with SSQA because I enjoy the freedom to buy used implements or rent something I can’t justify buying. If you only intend on buying new implements and never renting or borrowing implements then the JDQA is probably fine.
   / skid steer quick attach or not? #6
... The JDQA is probably better in the application it’s used than SSQA but the pool of available implements for SSQA is a lot bigger.
What is it about the JD quick attach that you like better in this application? It's been a while since I looked closely at one, but I did not notice anything "better", it was just different. On the other hand, I was not really looking to make a comparison at the time.
   / skid steer quick attach or not? #7
I've just a bucket and set of forks for my 430 FEL and prefer the JD design rather than a more cumbersome SSQA used on the skidsteers. For the size of my FEL, there are no other attachments such as those used on the skidsteers with hyd. hookup that are of any use to me.
The lighter weight and tighter package of the JD design are preferred.
But no problem with anyone else using what they want....just saying....
   / skid steer quick attach or not? #8
Guess I don't know what they look like. Got some pics?
   / skid steer quick attach or not? #9
I don’t like it better because it really limits your implement choices but I think it’s a lighter and simpler design.
   / skid steer quick attach or not? #10
Here is the JDQA setup:
2011 Nissan Juke SUV (A51694)
2011 Nissan Juke...
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
2013 Ford E450 Shuttle Bus (A53117)
2013 Ford E450...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2015 Hustler Super Z VX4 72in Zero Turn Mower (A51691)
2015 Hustler Super...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
