Skid Steer Quick Attach, as a Trailer Anchor?
   / Skid Steer Quick Attach, as a Trailer Anchor? #1
jigs_n_fixtures
Veteran Member
Salmon, Idaho
TYM T233 & T293 CAB
So, I’m thinking on ways to secure the tractor on the trailer, and had the thought that I could weld a SSQA plate onto the trailer and clip into it to secure the front of the tractor.
Any thoughts positive or negative would be appreciated.
Thanks, Jigs
   / Skid Steer Quick Attach, as a Trailer Anchor? #2
I can't tell you why, but in the back of my head I feel like it's a bad idea. However, at face value, it seems like a useful and unique way to secure your machine.
   / Skid Steer Quick Attach, as a Trailer Anchor? #3
Probably would not pass many state's regulations for securing a tractor load. I would read up on those for your state and also ask someone in the know of those regulations before going to the trouble and cost. I like the way you are thinking though. I've often thought if a guy came up with a slick way to secure a tractor and could get it patented and it would meet regulations, they would make some coin.
   / Skid Steer Quick Attach, as a Trailer Anchor? #4
I do not think it would pass a DOT inspection as the loader is not firmly mounted to the tractor (hydraulics are not firm). When tying down a piece of mobile equipment it must be tied down on 4 corners. However for a homeowner who would not be inspected it would probably work. I like the idea for a light piece of equipment like a TYM T233.
   / Skid Steer Quick Attach, as a Trailer Anchor? #5
Dont think its legal.....Check locale/state/DOT laws regarding loads on trailers.... Here is Cali it specifies using 4 tiedown from solid anchor points on tractor (or any vehicle) to anchor points on trailer.... I use four 2,500 lb working 10,000 lb burst ratchet straps left over from my race car days... Easier to deal with than chains and binders... I even added good tie down points to trailer (when using it with race car) because what was supplied from manufacturer was not adequate..... My whole tie down philosophy is I am not going to be the guy beside the road with tractor upside down in the ditch....
I think we all want to be this guy
   / Skid Steer Quick Attach, as a Trailer Anchor? #8
   / Skid Steer Quick Attach, as a Trailer Anchor? #9
I think everyone's covered using the ssqa for securement, in fact using the ssqa to secure an attachment (bucket, forks, etc.)
to the tracktor reqires a separate, additional securement chain in addition to chaining the tractor.
   / Skid Steer Quick Attach, as a Trailer Anchor? #10
So, you want to weld it against the headgate of the trailer ?
It would require exact alignment to the QA plate or it wont latch. And when the tractor wanders around just a little bit during travel, it will be under tension so you'd need a hammer to unlatch it. It just seems an unpractical idea to me.
2023 Polaris AWD ATV (A46684)
2023 Polaris AWD...
Ford Carry All, New Deck  (A47371)
Ford Carry All...
20ft Chain-Bottom Potato Box (A47369)
20ft Chain-Bottom...
1985 17ft. Bass Tracker Guide Special V-17 Boat and Trailer (A49339)
1985 17ft. Bass...
Cardinal Aluminum Corn Elevator (A49251)
Cardinal Aluminum...
2015 Chrysler Town & Country Van (A46684)
2015 Chrysler Town...
