Skid Steer Quick Attach, as a Trailer Anchor?
/ Skid Steer Quick Attach, as a Trailer Anchor? #1
jigs_n_fixtures
Salmon, Idaho
TYM T293 CAB, & T233
So, I’m thinking on ways to secure the tractor on the trailer, and had the thought that I could weld a SSQA plate onto the trailer and clip into it to secure the front of the tractor.
Any thoughts positive or negative would be appreciated.
Thanks, Jigs
/ Skid Steer Quick Attach, as a Trailer Anchor? #2
I can't tell you why, but in the back of my head I feel like it's a bad idea. However, at face value, it seems like a useful and unique way to secure your machine.
/ Skid Steer Quick Attach, as a Trailer Anchor? #3
Probably would not pass many state's regulations for securing a tractor load. I would read up on those for your state and also ask someone in the know of those regulations before going to the trouble and cost. I like the way you are thinking though. I've often thought if a guy came up with a slick way to secure a tractor and could get it patented and it would meet regulations, they would make some coin.
/ Skid Steer Quick Attach, as a Trailer Anchor? #4
I do not think it would pass a DOT inspection as the loader is not firmly mounted to the tractor (hydraulics are not firm). When tying down a piece of mobile equipment it must be tied down on 4 corners. However for a homeowner who would not be inspected it would probably work. I like the idea for a light piece of equipment like a TYM T233.
/ Skid Steer Quick Attach, as a Trailer Anchor? #5
Dont think its legal.....Check locale/state/DOT laws regarding loads on trailers.... Here is Cali it specifies using 4 tiedown from solid anchor points on tractor (or any vehicle) to anchor points on trailer.... I use four 2,500 lb working 10,000 lb burst ratchet straps left over from my race car days... Easier to deal with than chains and binders... I even added good tie down points to trailer (when using it with race car) because what was supplied from manufacturer was not adequate..... My whole tie down philosophy is I am not going to be the guy beside the road with tractor upside down in the ditch....
I think we all want to be this guy
/ Skid Steer Quick Attach, as a Trailer Anchor? #8
/ Skid Steer Quick Attach, as a Trailer Anchor? #9
I think everyone's covered using the ssqa for securement, in fact using the ssqa to secure an attachment (bucket, forks, etc.)
to the tracktor reqires a separate, additional securement chain in addition to chaining the tractor.
/ Skid Steer Quick Attach, as a Trailer Anchor? #10
So, you want to weld it against the headgate of the trailer ?
It would require exact alignment to the QA plate or it wont latch. And when the tractor wanders around just a little bit during travel, it will be under tension so you'd need a hammer to unlatch it. It just seems an unpractical idea to me.
/ Skid Steer Quick Attach, as a Trailer Anchor? #11
Yeah, What Renze said makes a lot of sense, plus it would only technically cover the requirement to strap down the hydraulic equipment (aka the loader) and not cover the equipment itself as others stated.
/ Skid Steer Quick Attach, as a Trailer Anchor? #12
It's a good idea if you also use bungees to secure your tractor
Your tractor hydraulics won't maintain any pressure you need mechanical fasteners
Woods 1050 3-Pt Backhoe (A66285)
Woods 1050 3-Pt...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
58in Wagon Wheel Bench (A65583)
58in Wagon Wheel...
2007 Ford F-450 Flatbed Truck, VIN # 1FDXF46P77EA72394 (A65563)
2007 Ford F-450...
W.R. Long Loader Tractor Brush Grapple (A66408)
W.R. Long Loader...
Four (4) John Deere 8R Front Fenders (A65640)
Four (4) John...
