Front-End Loader Skid steer quick attach adapter
/ Skid steer quick attach adapter #81
I hope I can bump this up to ask a specific question.
I have both a JD210LE FEL and a Case Construction King 850 backhoe. I'd like to install an adapter plate so I can use SS attachments. I'd prefer to put it on the Case.
Anyone have any sources they can share?
/ Skid steer quick attach adapter #82
Try these guys. Adaptor Plate
/ Skid steer quick attach adapter #83
Great my friend. Thank you.
/ Skid steer quick attach adapter #85
Call EA they are a dealer: WR Long Attachments For Sale Online!
/ Skid steer quick attach adapter #86
I'm told that these are really for thew small units. Not for commercial construction equipment. Too heavy duty for the implements. But I think I'm still going to pursue this. I'm not looking at this for heavy duty work. Right now I need to do some concrete. Skid steer equipment has a really nice variety of stuff. A concrete mixer is one of those items.
I'm not looking for a permanent solution to something, just more options.
/ Skid steer quick attach adapter #87
Does anyone have a link to the actual dimensions of the SSQA on the loader side? i can find the plate info easy and back engineer it sure but i'd rather be right the first go, and 2hrs of searching has not reviled a useful source.
I refuse to pay that kind of money for something i can simply build from trimmings under my bench.
Thanks all.
/ Skid steer quick attach adapter #88
Thanks all.
This drawing gives the needed dimensions:
/ Skid steer quick attach adapter #90
I have a older FEL (Kelley 500) with a single dump cylinder; what are the pros and cons on building an SSQA adapter for it? Would it be better to convert the FEL to have two dump cylinders?
/ Skid steer quick attach adapter #91
Pro: Almost everyone that has SSQA likes it.
Con: Lose some lift capability.
Not unless it has weak rollback.
/ Skid steer quick attach adapter #92
The rollback seems strong. My concern is how strong do I need to build the SSQA adapter for the single dump cylinder in the middle vs having the two cylinders in-line with the lift arms. What is your opinion: would it be easier to build a stronger adapter or add a second cylinder? I am already planning on re-plumbing the FEL anyway.
/ Skid steer quick attach adapter #93
I think it would be easier to build the adapter, than get the cylinder size, stroke and mounting locations right.
Mine only has one cylinder :D.
