Skid Steer or CUT for Road Maintenance?
   / Skid Steer or CUT for Road Maintenance? #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
I currently have two tractors and am considering a third to use exclusively for maintenance on my 1.25 mile private road. I do a lot of grading, ditch work, hauling & spreading material, etc. Some of the work is in tight spaces. Ignoring the significant difference in price between a CUT and a skid steer, what would you choose and why?
   / Skid Steer or CUT for Road Maintenance? #2
"What would I choose?" I'd save my money and use what I have. With two decent sized tractors you surely don't need another for dedicated driveway maintenance, even if it is over a mile. Do you have a front end loader, box scraper, landscape rake and rear blade? If not, those are the implements I would need for your listed jobs.
"Why?" 1) I don't have room for another tractor. 2) I have all the implements I need for driveway chores. 3) I cannot justify the big money for a decent skid steer and the implements required. 4) I have access to a neighbor's skid steer if I ever have the need, (only needed it once in past 15 years).
   / Skid Steer or CUT for Road Maintenance? #3
I dislike the "steer" part of a SS. Unless you have a 5th wheel on a wheeled machine a SS is rough on the turf and ground. They can be jerky as well. Tracks are a whole different set of issues. All that being said a SS can't be beat for efficiency, capacity and fitting in tight spaces. They also have great flow rates for hydraulic attachments. For me personally, I can't stand having to get in and out of the seat.
And what JJT said.
   / Skid Steer or CUT for Road Maintenance? #4
Based on my experience I'd say tractor with implements listed above.
CAVEAT: My driveway has been paved for 30 years, is only 0.0568182 miles long and I've never operated a SS :)
   / Skid Steer or CUT for Road Maintenance? #6
It sounds like you have plenty to spend if you are considering buying a dedicated piece of equipment strictly for the maintenance of your driveway , so if money was no object I would get a 75 HP tracked SS to stay out of having to use DEF fluid and because there really is no comparison to a tractor and a SS when doing dirt work, If you do look at skid steers I would highly recommend a slide up overhead door verses a fold out door, with the overhead door it doesn't matter where your arms are raised you can still enter and exit the cab which is a must when working by yourself, with a foldout door you can't.
Good luck. Charlie.
   / Skid Steer or CUT for Road Maintenance? #7
In my hands, the relative short wheelbase of a skid steer/CTL makes forward grading difficult. (Each hump or dip under the wheels is magnified out at the implement. Seems like most operators back-drag in float mode if they can.
Also, unlike a 3ph tractor, if you want to tilt the blade in the vertical plane, you'll probably need an expensive implement.
   / Skid Steer or CUT for Road Maintenance? #8
I have a mile of road to maintain. I have a 50 hp tractor and a 50 hp SS. The tractor is best for the road maintenance with either the box blade or the landplane. It takes both attachments to meet do all the work.
There is a grader blade attachment available for a SS with forward wheels but they are too expensive for me and finding one used close by has proved impossible so far.
   / Skid Steer or CUT for Road Maintenance? #9
I have a tractor and a tracked SVL 65 Kubota. While I can grade with the SVL, my preference is to use my tractor. I can grade better with the tractor. Which can probably be attributed to the fact that I have hundreds of hours more use on the tractor than the SVL 65. A more skilled operator can most likely do this with ease. Just because you buy a skid steer, it does not come with the experience.
1993 48’X96”  STRAIGHT FLATBED (A45046)
1993 48’X96”...
2014 Chevrolet Express Cargo Van (A44571)
2014 Chevrolet...
2012 Fiat 500c Convertible (A42744)
2012 Fiat 500c...
2019 SolarTech Silent Sentinel Towable Arrow Board (A42742)
2019 SolarTech...
Bush Hog 3510 10' PT Mower (A44501)
Bush Hog 3510 10'...
Pallet of Irrigation Hoses (A44502)
Pallet of...
