Skid Steer LS140
   / Skid Steer LS140 #1
marty
Mid West
Boomer 33D
I currently have a tremedous squealing noise when I raise and lower the boom. The skid has 540 hrs on it and all the joints have been greased at each routine service. It does not appear to be rubbing on the wear bars.
This noise has always been there, but now you can hear it over a half mile away. Has any had this occur before?
Thanks in advance for your time!
   / Skid Steer LS140 #2
Do your hydraulics seem to be ok? Possibly low on oil. Are all of the grease fittings taking grease? I would bet that one is not. I have seen numerous units with the squealing I imagine you are hearing and it is usually caused by a pin not getting grease. Dirt and old grease gets packed into the holes in the pin that allow the grease to come out in the middle of the pin. Removing the pin and clearing out the hole is the only fix.
2021 Troy-Bilt TB110 21in Push Mower (A55973)
2021 Troy-Bilt...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
Bucket (A55973)
Bucket (A55973)
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
