Quick Hitches Skid steer attachments disconnecting
   / Skid steer attachments disconnecting #11
Pictures of the gap the guys are talking about:
And the stop above the latching pin when latched:
This shows the over center travel so the latch can't push the handles up:
   / Skid steer attachments disconnecting #12
Great pics X!!!! Thanks for adding them!!!
   / Skid steer attachments disconnecting #13
Wouldn't you want to make sure both of the bolts are adjusted correctly before breaking out the welder?
   / Skid steer attachments disconnecting #14
You're welcome. Pictures make it easier for those with little or no experience to understand the written word.
Yep, that is a good plan. :thumbsup:
   / Skid steer attachments disconnecting #15
Thanks for loaning me the picture :cheers:
   / Skid steer attachments disconnecting #17
I'd assume that adjustment isn't the issue. The pins are spring loaded & the levers go over center. That means the springs are keeping constant pressure on the pins. Combine that with the wedges on the top & angle on the pins keep the SSQA tightening as it vibrates or wiggles.
My first set of pallet forks from Titan was similarly out of spec. The pins only barely engaged the holes on the forks. They refunded some of the price, in theory to have a local welder fix things. I just welded some bar stock to the bottom of the holes so the angle on the pins would have something to grab on & tighten up the SSQA.
   / Skid steer attachments disconnecting #18
Well yea, but in the above picture there is about a 1/2" of thread that you could use to extend the pin. If the pins are worn that much, why not just replace them?
   / Skid steer attachments disconnecting #19
View attachment 564636 View attachment 564637
Does this gap, or something close, exist with all your SSQA implements? If so, It could be wear or distortion on the FEL SSQA lifting brackets. Welding a shim or a heavy bead to the top of the plate will reduce that gap. Care must be used to maintain proper implement alignment.
I borrowed one of Xfaxman's pics to illustrate.
   / Skid steer attachments disconnecting #20
My ssqa grapple unlatched on one side couple years ago. I shimmed and slightly extended the top flange. I almost got it too tight. A bit more difficult to install. But no more worries about it coming loose. Really hard on the ssqa plate when this happens.....
1990 TRAILMASTER CRUDE TRAILER (A55745)
1990 TRAILMASTER...
1965 Rodgers T/A Equipment Trailer (A53117)
1965 Rodgers T/A...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
JET BAND SAW (A55745)
2013 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2013 FREIGHTLINER...
