Skid plates to protect filters and suction tube
   / Skid plates to protect filters and suction tube #1
Jeff244
Southern IL
Kioti DK 65C
I have a Kioti DK65C and I keep denting the hydraulic filters and now I bent the suction tube causing a leak as well as it now sucks in air and the hydraulic system is very jumpy(at least I assume thats what is causing the problem). My property is about 95% wooded and I am making/maintaining trails and moving fallen trees often. I have a new suction pipe on order and will try to install it when it arrives(has been on back order for over a week). I have a welder but not a lot of skill with it. Any ideas would be appreciated.
Thanks,
Jeff
   / Skid plates to protect filters and suction tube #2
Sounds like a good time to get alot of practice with your welder.
Get under your tractor with a tape measure and just figure out how much coverage and where you can bolt skid plates to.
wushaw, you are right. There are not many places that I can bolt anything to. Is it OK to weld a bracket to the tractor frame? That would make it much easier.
   / Skid plates to protect filters and suction tube #4
I am working on a deal right now and if I get the sale we will be armoring a DK65 up we will be plating up the underneath.
We will also be running brush and limb risers up over the hood and operator.
I WILL be posting pictures along the way and maybe if it's not to bad I might be able to make some instructions to help you along.
Rick
Rick, wow, that would be great.
Jeff
   / Skid plates to protect filters and suction tube #6
Sounds like the Wallace route would be good.
Welding to the frame is ok just as long it is frame material and not any cast part of the tractor and that is just because it takes preheat and real slow cool down and nickle rod to welding cast.
Welding 90° angles in strategic spots with nuts welded to the angles ( or the other way around) would be good attach points.
   / Skid plates to protect filters and suction tube #7
I thought the same thing, but after checking it out, if I needed to get under there to change out filters, plugs, components etc., I'd have to cut it off. Maybe you could weld some nuts to the frame and make your skid plate with holes so you can bolt it to the nuts or visa versa? You'd solve that problem anyway.
wushaw, 3RRL, I definitely would need the plate to be removable and I will be careful what I do weld to on the tractor. I will make a plan of my own and wait for info from Rick Wallace before getting too far into it. I really appreciate the input.
Jeff
   / Skid plates to protect filters and suction tube #9
I am also in the business of mowing on rightofways. I took a piece of 1/8in plate that was long enough to go from the back of the front axle to the rear hitch and had it bent on a brake so it had sides that went full length. Near the rear where the filters, linkages, and hoses were, I made flanges on the top of the sides that flared out to cover any exposed plumbing. I bolted it to the loader frame in front so it could hinge down from the back. You will need to clean it out regularly as it will fill up with leaves, grass and such. With the loader on I haven't had the need for putting on tubing to protect the hood and me. Going through blackberry vines 12+ ft hasn't been a problem. I just pat them down in front while the mower is at work.
The one thing you might think of before you go out, If you are using a bush hog type of mower is to reinforce the deck and sides. I have been using mine for 12yrs and you can't hardly tell it. I have however gone through many blades and dishes. I put 3/16 plate under the top deck and 3/8 down the inside on both sides. As you know the left side takes the most of the beating. Also I use the blades that are tipped up in the back. When you hit a rock or the unknown, the back of the blade will come in contact with the deck, much better than having the cutting edge opening the deck like a sardine can. Been there.
One more thing, you might want to weld a threaded end of pipe over the valve stems so you can cover and protect them. I have had one experience of shearing one off, of course it had to be the rear,
   / Skid plates to protect filters and suction tube #10
What you really want to do is make a sub frame like they do for a backhoe. You want the sub frame to take all your impacts not the points where the skid plate is bolted to the tractor. You need to disperse the energy not direct it. Look at your tractor and look where the factory sub frame mounting points are and start with that. Then I would strongly recommend drilling and taping into the sub frame to mount your plates. Bear in mind a tractor is not a frame design vehicle. Directing impact to the drive line can total the tractor. A tractor is a drive train with wheels and a place to sit and thats it
2016 Club Car Carryall 1500 4x4 Utility Cart (A50322)
2016 Club Car...
Mayrath Swing Away Auger 10-62 (A50514)
Mayrath Swing Away...
New Holland 276 Square Baler (A50774)
New Holland 276...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
John Deere 1023E (A50120)
John Deere 1023E...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
