Skid plate
/ Skid plate #101
When all else fails, look up the original drawing! Ignore my comments about 30 degrees as that is the bend in the skid plate and not relevant to the attachment point. So, here is the drawing that we used to fabricate the skid plate for the loader hydraulics area. As Murph noted, the drawing Bob posted showed a 22 degree angle for the attachment point angle iron. When he tried that it did not fit. A 15 degree angle for that piece did work. As noted earlier, for my early DK40 (2007), the angle would be zero degrees as the FEL support frame runs directly front to back rather than being angled as it is today.
http://www.tractorbynet.com/forums/...ing/261660d1334946360-skid-plate-scan0002.jpg
/ Skid plate #102
IT, I asked cause I have that extra one you made and don't know what to do with it. You want I send it back.
/ Skid plate #103
I looked back further in the thread and found pics of the angles you're referring to. I think they are on page 2, in addition to the drawings Bob42 showed on post 62.
I will measure mine when I find time and report back.
No CM, They are not on page 2. Some photo's are on page 2 but no drawings. They are on page 62 like I told you.
/ Skid plate #104
No, mine is flat and I need to make measurements and just fabricate another one. Please do pass on the 22 degree version to whomever wants it. Remind them they'll need to grind off that stupid extra welding I did on the angle iron contact point though. Ten minutes with a grinder ought to do it.
/ Skid plate #105
It seems a little hard to pass it along.
/ Skid plate #107
Murphy and IT, I've looked at the drawings Bob did on post #62 AND I've looked at the pics in post #16 on page #2. The first three pics on post #16 show where the 22 or 15 or whatever degree the attachment piece would be at as a result of the bend, or not in the frame piece in that area in question.
I was having trouble understanding where you were looking for the measurement to take place until I compared the pics to the drawing(s).
Now that I'm orientated to the area I'll give you my measurement angle ASAP. OK?
/ Skid plate #108
Hey Murph,
I measured and got around 12-15 degrees max. on my frame. Does that help?
Are you wanting to toss me the 'extra' plate for shipping costs, or something like that, I'm wondering?
/ Skid plate #109
Coyote machine said:
Hey Murph,
The extra plate was welded with a 22 degree angle based on Bob's CAD drawings. That is why it didn't fit Murph's tractor as I recall. He can confirm. I'm afraid the extra one is destined for the scrap pile.
/ Skid plate #110
Yeppers, its a 22% allright.To the scrap pile it goes.
/ Skid plate #111
/ Skid plate #113
Less work and hassle to make a new one.
Yeah, I figured as much- can you make me one since you've made a few, or should I look closer to home and just adjust the angle to fit my specific situation?
I wonder why there are as many variations on the angle on the frame piece?
/ Skid plate #114
Coyote I don't have any more blanks to start with. I had a few cut by a metal shop but used them all.
The dimensions in Bob's CAD are accurate except for the attachment point angle. All you need besides the 3/16 blanks are a press brake, drill press and welder. You could skip the welder and just bolt them together too. Any metal shop could cut the blanks and put the 30 degree bend in. Even a hand drill could be used for further assembly though a drill press is easier. If you have a welder you can make one up without the press brake just by welding a piece at the 30 deg angle.
/ Skid plate #115
Commander this thread scan down ti bobs pics
/ Skid plate #116
Looks like I'm skrewedd. Now I have a plate I paid a lot to ship here and it won't work.:censored:
/ Skid plate #118
Not sure yet, just going by what we discussed previously in this thread- seems that plate was supposed to go to the scrap pile- I should have come back here to determine what the case was before having it shipped. Now I may have to re-engineer it or start fresh, don't know yet....:confused3:
/ Skid plate #119
If the angle is off grind the mount off and reposition it. IT made me a new one cause I can't weld.
/ Skid plate #120
Yeah, I get what will need to be done. I don't have welding equip any more.
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
Cattle Feeder (A65640)
2013 FORD F-550 SUPER DUTY (A65643)
2013 FORD F-550...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
(16) Kinze 3000 Precision Plant Corn Meters (A65640)
(16) Kinze 3000...
2024 Wolverine X2 1000 R-Spec (A62679)
2024 Wolverine X2...
