Skat Track 1300HD info or Kubota V1903
   / Skat Track 1300HD info or Kubota V1903 #1
ziegler
Royalton, ny
Scat Trak 1300HD; MF 65 gas; TYM T474
If everything works out I will be picking up a 1300HD soon. Looking for any information or PDF's that you can share. Has a v1903 and there are wiring problems, what is needed to make it start relay-able - just 12v to the starter solenoid & glow plugs or is there more need - manual fuel pump and shutoff?
It was told it has a power problem but will start and run with black smoke until it warms up then it goes away, he could not get it to start when I was there - the left cab panel was off and he was paying with the wires. A friend pull the head and did something with the valves and new head gaskets but no change (planing on a compression test after I get it home). He is not totally sure what was truly done but thinks the valves where lapped. There is oil at the top of the radiator should I be worried - enough to coat my finger but I am assuming this is from removing the head, will be doing a radiator pressure test to make sure. Or should I just look for another engine? A local guy has a Isuzu 2.2 for $700 from a refer trailer.
   / Skat Track 1300HD info or Kubota V1903 #2
The black smoke means not enough air for the quantity of fuel delivered, or over fueling, possibly a stuck rack. Check the air cleaner?
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2016 Chevrolet...
American G-Model Pump Jack (A53473)
American G-Model...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
