Skat Track 1300HD info or Kubota V1903
   / Skat Track 1300HD info or Kubota V1903 #1
ziegler
Royalton, ny
Scat Trak 1300HD; MF 65 gas; TYM T474
If everything works out I will be picking up a 1300HD soon. Looking for any information or PDF's that you can share. Has a v1903 and there are wiring problems, what is needed to make it start relay-able - just 12v to the starter solenoid & glow plugs or is there more need - manual fuel pump and shutoff?
It was told it has a power problem but will start and run with black smoke until it warms up then it goes away, he could not get it to start when I was there - the left cab panel was off and he was paying with the wires. A friend pull the head and did something with the valves and new head gaskets but no change (planing on a compression test after I get it home). He is not totally sure what was truly done but thinks the valves where lapped. There is oil at the top of the radiator should I be worried - enough to coat my finger but I am assuming this is from removing the head, will be doing a radiator pressure test to make sure. Or should I just look for another engine? A local guy has a Isuzu 2.2 for $700 from a refer trailer.
   / Skat Track 1300HD info or Kubota V1903 #2
The black smoke means not enough air for the quantity of fuel delivered, or over fueling, possibly a stuck rack. Check the air cleaner?
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
1996 STOUGHTON TRAILER DRYVAN (A53843)
1996 STOUGHTON...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53473)
2012 NEW HOLLAND...
2002 International 9200i Truck (A53473)
2002 International...
