Sizing hydraulics correctly
/ Sizing hydraulics correctly
Larry, You are getting me into trouble here! Your suggested motor could be used on my mower, rototiller, post hole auger, baler etc with little or no additional expense. No PTO shafts to hook up. No need to worry about my Jubilee not being live PTO. All I would need is a couling on each piece of equipment. Gonna loose sleep tonight!
Dave
/ Sizing hydraulics correctly #22
35 HP can push 20 GPM @ 2500 psi, using a 1.7 cu in pump
20 GPM/2800 psi = 1.7 cu in pump
Motor @ 8.5 cu in @ 20 GPM = 544 rpm
MOTOR TORQUE = 8.5 cu in = 2500 psi = 3348 in lbs/279 ft lbs
Motor HP @ 85 % eff = 29.75 HP
More info coming soon. (A64557)
More info coming...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
BRADLEY MACHINE MINI VAC TRAILER (INOPERABLE) (A67714)
BRADLEY MACHINE...
