Sizing an inline fuse
/ Sizing an inline fuse #1
gobbler
NE Missouri
Kubota BX1800
Ok guys, how does one size a fuse for a particular application. I've got a sprayer w/ a pump that pulls 7amps. I'm wiring up a switch and want to put in an inline fuse. How do you decide what size fuse you should use ???
Jim
/ Sizing an inline fuse #2
gobbler,
i'm no expert....but in general, the fuse is sized to protect the wiring not the load device. for example a # 14 wire can handle about 15 amps...so you'd want a 15 amp fuse on that wire even if the load is only 7.0 amps. this way, if there is a short, the fuse will blow before the wire heats up enough to burn up !!
for your application, i'd run a # 12 wire ( bigger is better !! ) and start with a 10 amp fuse. if the fuse blows, i'd step up to a 15 amp. you're still safe with that wire size up to 20 amps. slow blow fuses are good for motor loads to help tolerate the high inrush amperage when the motor starts.
good luck !!
/ Sizing an inline fuse #3
gobbler,
In the Engineering world:
Keep in mind that an electric motor draws more current on startup. In some cases a lot more current for a very short period of time. Also if you stall the motor it will draw more current. So the ideal way to go about this would be to look at the motor and see if it specs a max or peak current in adition to the contious operating current which is the 7 amps.
You could then use a fuse that is rated just slightly over that max or peak current. If the number is not on the motor then the manufacturer could tell you the details.
In the real world:
Start with a 7 amp. Since the start current is so short in duration you won't need a 15 amp fuse. So start with the 7 amp and if that blows slowly increase it by 1-2 amp increments until it does not blow.
Also if you use a slow blow fuse, it would be less sensative to the current spikes of startup and still provide protection, just not as sensative protection.
Remeber it is better to have a fuse that is just bigger than the normally operating current so if a problem occurs you can minimize the damage to the wiring, motor, etc...
Phred
Thanks guys,
I picked up an automotive (blade) inline fuse holder last nite. I've already got various fuses, so I went with the blade type instead of the glass tube type. I'll be finishing the wiring after work today.
/ Sizing an inline fuse #5
the idea of starting out with a certain size fuse and increasing until the fuse does not blown was actually written in the NEC code book in one of its versions.
Dan L
/ Sizing an inline fuse #6
The amount of current that a wire will carry also depends on the insulation around the wire and how tight and many are in a bundle. The Alpha Wire Company specs the following:
18 AWG PVC @18 amps
16 AWG PVC @24 amps
14 AWG PVC @33 amps
12 AWG PVC @45 amps
10 AWG PVC @58 amps
This is single conductor in free air 30C ambient Temp
Dave
/ Sizing an inline fuse #7
Ok! now I am confused. I always thought that according to the NEC #14 is fused at 15A #12 is fused at 20A. Now I know that is for AC wiring. Is DC different on the fusing?
/ Sizing an inline fuse #8
Dave is right. It depends on the wire (romex, THHN, etc..), and the operating enviroment.
I think in this case the wire size is not improtant as long as it can handle a heafty safety margin over the 7 amps. Obvoiulsy even if you used #8 wire (Which is good to more than 30 amps) you would not want a 30+amp fuse to "protect" a 7 amp motor.
Dan; Those NEC guys really had to give that a lot of thought!
Standard engineering practice; Calculate the correct value to three decimals, double that value for a safety factor, and when that does not work keep trying values till something does work!
Phred (AKA Fred)
/ Sizing an inline fuse #9
I think some confusion concerning wire size is abound here. The normal practise is to select the wire size accorrding to the load the wire is to carry. The other confusion is that not only is the wire fused to protect the wiring, it is also assumed that the load is also fused to protect it. Normally since the load and wire size is matched, one fuse size is used to protect both wire and load. If you choose to use a wire able to handle a larger load then you are using, maybe because it is handy, then you better fuse to protect the load for the wire size it self will protect the wire since the load will not damage the wire.
Dan L
/ Sizing an inline fuse #10
I'll add a little more confusion. Line loss or line resistance will reduce the voltage that the motor sees as to the voltage at source (battery/alternator.) The number of connector contacts will also add to the total resistance. Which means a larger wire will have less DC resistance than a smaller diameter wire. This should not make much of a difference on a small tractor. If I were going to wire up my tractor for a 7-amp motor I would use a 16 or 14AWG wire. I’d make sure that all the contacts were sized for the wire that I was using.
Dave
/ Sizing an inline fuse #11
Dan,
Your absolutely correct. I should have made that more clear.
My general policy is to oversize the wire a bit since it cost little to do so for all but the longest of runs. Then the load only needs to be considered for the fuse size. Particularly for 10-20 feet of small gauge wire like you would need for this application.
#8 and larger is a different story since this stuff gets pricey.
Fred
/ Sizing an inline fuse #12
There's another facet to the sizing of "protection" that is often misunderstood. A fuse or breaker sized to protect a load rarely protects the load in the sense that it prevents the motor / light / heating element from going bad. On occasion, a motor may be protected in an overload event, but the fuse or breaker most often blows or trips after the load already took a crap. It is common to have 15, 20 or larger amp protection on circuits that normally see a fraction of that current.
For protection of motors, the common method is to either have built-in thermal protection or a motor starter with same. Fuses and breakers are there primarily for short circuit (wire) protection. There are not enough sizes of fuses available for proper protection of loads. Thermal elements for a motor starters, especially for smaller motors, have ranges like 3.56A to 3.95A, 3.96A to 4.23A, etc. They don't jump in 1,5 or 10A increments.
For lighting and power circuits, it is not uncommon to have wiring connected to the circuit that would be considered undersized for the circuit's fuse or breaker. Two examples are a fluroescent light - they have 18ga wires for the line side of a ballast, but are connected to 15A circuits in a residence (larger circuits in commercial applications). Another is the circuit your computer is plugged into. At home, you have 15 and 20 amp circuits, depending mostly on the room you're in. The electrician has no idea what you will come along and plug in. There are requirements for circuits in different living spaces, but they do not address protection of devices you come along and connect. If you plug a radio or clock or table lamp into a 20 amp circuit in your kitchen, the fuse or breaker has no way of knowing it's not the coffee pot. The load you plugged in may need less than an amp to operate properly, have some kind of internal problem, and draw 12 amps and smoke. Meanwhile, the breaker assumes all is well because that current well below its max................chim
/ Sizing an inline fuse #13
My comments deal only with motors and industrial wiring. House wiring is something else and I would never attempt to tell any one that I knew much about that. Too many assumptions for me. Just give me a motor to control!!!
Dan L
/ Sizing an inline fuse #14
Here's yet another bit of fuel to add to the confusion fire.
A fuse does not "blow" instantaneously at its rated value.
For instance, a 10 amp fuse with 10 amps of current flowing through it might last for several minutes, maybe even an hour before it fails. As the current overload increases, the "fail-time" decreases. A 20 amp current draw might cause the fuse to blow in a second. A 40 amp overload might blow the fuse in 0.1 second.
I've attached a generic pic showing the fail-time vs. % overload for three different types of fuses. The green line might represent a "slo-blo" type where the red line would represent a "fast-blo" type.
Therefore, if the fuse is being used to protect the device, a lot of information is needed as to what current is "excessive" and then a fuse with the correct "fail-time" and current rating needs to be selected.
Is everyone confused now?
~Rick
/ Sizing an inline fuse #15
I've changed in the past few years to using more in-line circuit breakers than fuses for primary power supply. Unless you have a dead short in the line, most blown fuses are caused by a surge of voltage pulled at initial activation of the light/motor/etc.
I use either auto or manual reset breakers as I don't have to go find a fuse. If the breaker continues to cycle, then I know I've got a problem.
Just a suggestion.
I usually order my stuff from either Terminal Supply or <A target="_blank" HREF=http://www.delcity.net>http://www.delcity.net</A>
Landhonor Quick Attach Log Grapple (A66285)
Landhonor Quick...
2013 International WorkStar 7400 Crane Truck, VIN # 1HTWGAAR0DJ296617 (A65563)
2013 International...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
2014 FORD F350 4X2 S/A DUMP TRUCK (A59914)
2014 FORD F350 4X2...
