Sizing a hydraulic motor
/ Sizing a hydraulic motor #1
toxic
PEI, Canada
Kubota m7060 , John Deere 4200, Kubota ZD 326 & ZD 21
Got a question for those who are more informed. I am building a power rake for my ctl and am rather stumped as to which hydraulic motor I should get to power the drum. My skidsteer on the low flow side puts out 21.8 gpm at 3000 max psi. I want the drum to turn around 250rpm and of course use the most available power as possible. Most motors I've seen with the correct hp and rpm are not rated for the flow or psi that the skidsteer is capable of putting out?
/ Sizing a hydraulic motor #2
21.8x231/259=20.143 cubic inch per rev. is what you want if you are going to run the skid steer at rated rpm. There will actually be a little loss but you won't notice it. A pressure relief valve can be added if necessary.
This one is close.
/ Sizing a hydraulic motor #3
In previous job we tested attachments on skid steers and found that most of them are optimistic on the amount of flow they produce at full pressure. I suspect the motor kwentling suggested would be a good fit.
/ Sizing a hydraulic motor #4
You can go over to Surplus Center website and plug those numbers into one of their free hydraulic calculators to determine what size motor you need to get those results. Then see if they have anything close.
2008 Toyota Camry Sedan (A64557)
2008 Toyota Camry...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2014 Dodge Ram 2500 Pickup Truck, VIN # 3C6UR5CJ6EG253763 (A65563)
2014 Dodge Ram...
2015 Chevrolet Silverado 2500 (A62613)
2015 Chevrolet...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
Westfield Seed Auger (A66408)
Westfield Seed...
