Tractor Sizing size?
/ size? #1
ChasK
Indiana
Kioti CK20
What is the biggest finish mower I can use with a Jinma 254?
Can I go 72", or is 60 the biggest I should try?
Thanks for your thoughts on this...
/ size? #2
Mine handled a 5 foot rotary cutter (bushhog) in H1, straining only on the more severe uphill runs - forcing me to drop into L3 for that. My Yanmar had a 5 foot MMM (finish), and had plenty of power to spare.
Since there's considerably less mass with a finish mower - and assuming reasonable mowing conditions - your JM254 should have no difficulty whatsoever with a six RFM .
//greg//
/ size? #3
70"is the biggest finish mower that you can use with a Jinma 254
/ size? #4
I have a 60" RFM on my 224. It handles it with no problems at all. I think a 72" on the 254 should work just fine.
/ size? #6
If this is for lawn duty, where you are not cutting "high" grass, the 6 footer should do fine. When you occasionally have "high" grass you will need to slow down. If you are using it more as a field mower, where high grass is the norm, the 5 footer is probably better. If thats the case though, you are probably better off (cheaper) with a 5' rotary cutter.
KENWORTH CAB AND HOOD (A65643)
KENWORTH CAB AND...
GREAT PLAINS 1006NT - 1575 NO-TILL GRAIN DRILL (A64277)
GREAT PLAINS...
Coleman Powermate 3750 Generator (A65579)
Coleman Powermate...
Reddick Crop Sprayer (A62613)
Reddick Crop...
Linx EQ07020RS 20ft Trailer (A65640)
Linx EQ07020RS...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
