Tractor Sizing size?
/ size? #1
ChasK
Indiana
Kioti CK20
What is the biggest finish mower I can use with a Jinma 254?
Can I go 72", or is 60 the biggest I should try?
Thanks for your thoughts on this...
/ size? #2
Mine handled a 5 foot rotary cutter (bushhog) in H1, straining only on the more severe uphill runs - forcing me to drop into L3 for that. My Yanmar had a 5 foot MMM (finish), and had plenty of power to spare.
Since there's considerably less mass with a finish mower - and assuming reasonable mowing conditions - your JM254 should have no difficulty whatsoever with a six RFM .
//greg//
/ size? #3
70"is the biggest finish mower that you can use with a Jinma 254
/ size? #4
I have a 60" RFM on my 224. It handles it with no problems at all. I think a 72" on the 254 should work just fine.
/ size? #6
If this is for lawn duty, where you are not cutting "high" grass, the 6 footer should do fine. When you occasionally have "high" grass you will need to slow down. If you are using it more as a field mower, where high grass is the norm, the 5 footer is probably better. If thats the case though, you are probably better off (cheaper) with a 5' rotary cutter.
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
72in. Skid Steer Bucket (A65640)
72in. Skid Steer...
Crane (A64194)
Crane (A64194)
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
Wolverine SBM-12-72W Skid Steer Sickle Bar Mower  (A62679)
Wolverine...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
