Tractor Sizing size?
   / size? #1
ChasK
Indiana
Kioti CK20
What is the biggest finish mower I can use with a Jinma 254?
Can I go 72", or is 60 the biggest I should try?
Thanks for your thoughts on this...
   / size? #2
Mine handled a 5 foot rotary cutter (bushhog) in H1, straining only on the more severe uphill runs - forcing me to drop into L3 for that. My Yanmar had a 5 foot MMM (finish), and had plenty of power to spare.
Since there's considerably less mass with a finish mower - and assuming reasonable mowing conditions - your JM254 should have no difficulty whatsoever with a six RFM .
//greg//
   / size? #3
70"is the biggest finish mower that you can use with a Jinma 254
   / size? #4
I have a 60" RFM on my 224. It handles it with no problems at all. I think a 72" on the 254 should work just fine.
   / size? #5
I have a Jinma 284 and have a 6' finish mower and it works fine.
Mark H
   / size? #6
If this is for lawn duty, where you are not cutting "high" grass, the 6 footer should do fine. When you occasionally have "high" grass you will need to slow down. If you are using it more as a field mower, where high grass is the norm, the 5 footer is probably better. If thats the case though, you are probably better off (cheaper) with a 5' rotary cutter.
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53473)
2020 New Holland...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
