size of Rotary Tiller for DK45SE HSK
   / size of Rotary Tiller for DK45SE HSK #1
CMOrr
East Texas
I am purchasing the referenced tractor and wanted to get a rotary tiller. I was considering the Howse RTC 70 (70"). I believe this tractor has a pto hp of 36. Will this tractor handle this tiller? I have been told it should but I thought I would run this by the forum to see what the thoughts are. The following is what is on the Howse website:
Rotary Tiller Section
A-frame and gearbox assembly can be reversed for reverse rotation.
Machine can be offset to either side or center.
A-frame extended for smoother operation.
#4 metric torque limiter driveshaft to protect tractor and implement.
Removable tine shaft and tines.
Adjustable skid shoes.
Model Weight Description
RTC48 647 lbs. 48" Rotary Tiller/ 20-50 hp 6 sets of 4 blades
RTC54 679 lbs. 54" Rotary Tiller/ 25-50 hp 7 sets of 4 blades
RTC62 737 lbs. 62" Rotary Tiller/ 35-60 hp 8 sets of 4 blades
RTC70 780 lbs. 70" Rotary Tiller/ 40-60 hp 9 sets of 4 blades
Thanks for the input.:)
   / size of Rotary Tiller for DK45SE HSK #2
You will be fine.
I run a 72" King Kutter II tiller on my DK 35 with no problem.
   / size of Rotary Tiller for DK45SE HSK #3
You will be fine.
same here, run a 72" on my 45 with no problem, think it would have handled the 81" one I wanted to buy easily.
MASSAGE CHAIR (A58214)
LOT: (8) Chain Binders (A59076)
LOT: (8) Chain...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
2011 PETERBILT 367 DAYCAB (INOPERABLE) (A58214)
2011 PETERBILT 367...
Sheets of Tin (A57149)
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
